Page 2 of 3
Re: Input latency makes my game unplayable...
Posted: 21 Sep 2025, 23:03
by destroyer4b
Had a same problem and tried everything possible fix.
Before few days i fixed with changing CS2 to windowed fullscreen mode, NVCP No scalling mode + NVCP Low Latency mode ULTRA + Nvidia Reflex in game to ENABLED (that was best combo for hit registration on my setup).
7800x3d
4070 TI
32 GB DDR5 6000mhz
240hz monitor
Posted: 22 Sep 2025, 03:09
by Lucasged
I will try this later. Never enjoyed to play with Low Latency Mode on ultra, but i will give it a try - i feel my hit reg gets worse with this setting.
Posted: 22 Sep 2025, 10:34
by cuaderno
Can you screenshot your video settings? Any launch options?
Posted: 24 Sep 2025, 05:26
by Lucasged
cuaderno wrote:
22 Sep 2025, 10:34
I'm 100% sure its not cause of my video settings or launch options.
Posted: 25 Sep 2025, 11:37
by Kal
destroyer4b wrote:
21 Sep 2025, 23:03
7800x3d
4070 TI
32 GB DDR5 6000mhz
240hz monitor
are you on FSO/FSE? GPU or display scaling?
Posted: 26 Sep 2025, 00:37
by destroyer4b
No FSO/FSE , GPU No scalling and UNTICKED
Try and let me know if this help you.
One more thing, I had also packet loss and net jitter and what fixed for me is rollback Realtek 2.5 ethernet driver to 7/29/2024 version.
Update : After testing couple of days, Nvidia Reflex OFF is even better instead of Enabled.
Posted: 26 Sep 2025, 07:15
by Lucasged
destroyer4b wrote:
26 Sep 2025, 00:37
No FSO/FSE, what does that mean?
Posted: 26 Sep 2025, 12:07
by Kal
Lucasged wrote:
26 Sep 2025, 07:15
destroyer4b wrote:
26 Sep 2025, 00:37
Full screen optimization/full screen exclusive
Posted: 27 Sep 2025, 12:06
by xtensei
destroyer4b wrote:
21 Sep 2025, 23:03
7800x3d
4070 TI
32 GB DDR5 6000mhz
240hz monitor
doesnt work tried soo many tweaks nothing works it will feel good for 1week max 2weeks then it will comeback
Posted: 03 Oct 2025, 10:58
by amorou
Lucasged wrote:
17 Sep 2025, 02:16
The issue is that after moving to a new apartment I’m experiencing so much latency that I can’t play CS2. I usually sit around 3500+ ELO, but now I can bottom-frag even when playing Premier or against significantly weaker opponents.
Things I’ve done since moving:
Bought a newer, better LAN cable
Tried adding a static IP address
Bought a new 400 Hz BenQ monitor
New mouse and new keyboard
Besides the new hardware, I’ve reset the PC and tweaked the BIOS, but I just can’t seem to find the problem.
The new apartment has the same internet setup as the old one—not fiber, but 1000/500 through a coax cable, exactly what I had before.
My PC specs:
AMD Ryzen 7 9800X3D
RTX 4070
Lancer Blade 6000 MHz CL30 32 GB
MSI MAG Tomahawk B650 WiFi
Arctic Freezer liquid cooling
Kingston NV3 SSD 500 GB PCIe 4.0 M.2
Thermalright 850 W ATX 80 Plus 3.0 Gold
I’ve also felt, ever since I built this PC about six months ago, that there’s been so much input lag/latency that I haven’t been able to play optimally.
Someone please help with this. Even my friends who tried to play a few rounds faceit told me that they feel it instant...
Either get electricty from high voltage lines via step down transformer only for your home
Or go off-grid , buy true sine wave inverter and couple dc batteries
Or next time moving ask electricty company how many houses your house share transformer with ( just ask how big is your transformer is ) They wont tell you , but if you head to headquarters and talk to some guy in there he might check for you if you lucky.
You will wonder how many kva is too much , well less is always better but I woudlnt move in if its bigger than 400kva ( it equals 400.000 watts )
My current home use 1500 kva xformer , pc and hifi runs shit here , all good places I tried uses smaller xformer ( they share less with other homes )
