CS2 reflex,gsync etc(New PC-newbie)
wasted42
Re: CS2 reflex,gsync etc(New PC-newbie)
Post by wasted42 » 28 Jan 2026, 02:34
kyube wrote: ↑
27 Jan 2026, 12:15
naporitan wrote: ↑
27 Jan 2026, 11:48
I think this is a misconception... Can you provide reputable research?
Open up FrameView and test yourself. Look at the Render Queue Depth column.
hurryupabit wrote: ↑
27 Jan 2026, 11:18
My monitor has no DYAC, It has only Gsync from nvidia compatible no dyac its benq xl2540 240 hertz . So what do you you recommend me to use?
I've already replied to you above....
No frame rate limiter (fps_max 0) & fixed refresh rate.
Enable Reflex.
That's the best you can do, assuming tearing is irrelevant to you.
Hello bro, can u help ? Here’s my setup:
CPU: AMD Ryzen 7 9800X3D
GPU: NVIDIA GeForce RTX 4070 Ti SUPER 16GB
RAM: HyperX Fury 32GB DDR5 6400MHz
Motherboard: MSI MAG B850 TOMAHAWK MAX WIFI
PSU: Corsair RM1000x 1000W
SSD: Samsung M.2 NVMe 9100 PRO Series 1TB
I’m also using a 400Hz BenQ monitor.
Would you recommend enabling V-Sync?
If yes, only in NVIDIA Control Panel or also in CS2?
Should I use a max frame rate limit in NVCP as well?
I’d really like to hear your suggestion, because I’m having a serious screen tearing issue, which I really shouldn’t be having with this setup.
