How do you check or meassure interference in the air?[email protected] wrote: β28 Nov 2025, 03:15Interference in the air is easy and cheap to fix with faraday fabric.
Partially fixed input lag and floaty mouse | UPDATE
Re: Partially fixed input lag and floaty mouse
u never fix it by socet filterRoxtar wrote: β28 Nov 2025, 03:03I see, anyways I think that's too much schizo, I try to focus on plausible things that can be proved/fixed, if we start searching for interference in the air we would never fix the issue.[email protected] wrote: β28 Nov 2025, 03:00That what he means:
Harmonic interference transmitted over the air is caused by high switching frequencies and wide frequency spectra, which propagate like radio waves and are particularly relevant in building technology.
They are caused by nonlinear loads such as frequency converters and can interfere with sensitive devices such as computers or lead to hardware failures and system crashes.
Disruptions to IT and communication systems: Massive disruptions such as operational failures, system crashes, data problems and screen flickering can occur.
False, it can be caused by multiple reasons, from faulty wire to a bad connection, it doesn't have to be necessarily a electric field problem, maybe in your case it is but not every case.
Again, maybe not your case specifically but I don't think mine is caused by air or electric fields, and I think it doesn't hurt trying to filter your electricity before start chasing interferences on the air, worst case scenario and your double conversion UPS doesn't work for you, just return it.
[email protected]
How's it useless? It already improved the issue for me by a large margin, I can instantly feel the difference when I turn on/off the online mode in the UPS. You're just projecting your frustration to others...
You can spend your whole life experiencing improvement from plugging something into an socet, but it won't fix the problem.
I'm telling you this only because I want to save you time and money.
I also experience improvement from connecting something metal between the PC and the socket, but believe me, a real fix costs a couple of bucks, and I wrote about this a long time ago.
and, if you think, your problem is socet, disconnect ups and play on battery, if you not feel instant fix, that is not socet.
3.5 aux cable and sound cardRoxtar wrote: β28 Nov 2025, 03:31How do you check or meassure interference in the air?[email protected] wrote: β28 Nov 2025, 03:15Interference in the air is easy and cheap to fix with faraday fabric.
I appreciate that, but in MY CASE filtering electricity thru a double conversion UPS is working, maybe your case is different and indeed caused by air interferences.
Something metal? Wdym.
I already feel the difference, that's why I'm stating it is electricity related
