Page 2 of 9
Re: Try my new app to fix input lag (cs2_timer_fix_by_yam1ke)
Posted: 17 Dec 2025, 07:11
by yam1ke
I released new version v3.6 (you can try it from reference in my previous post).
Configs from the past version are compatible!
The changes are minor but high-quality: as one of users noticed, registration was better on v3.0. And I was able to pull these changes into version v3.5!!!
I attached three configs right away. One for the best hitreg you've had (without phantom effect). The second and third one for light phantom I haven't tested properly (but you need to adjust LFO settings). To activate one of my configs from the archive, rename it to config.ini. If you have fewer than 8 cores, change the core number inside the config.ini
Posted: 18 Dec 2025, 05:29
by Lev1n
This config gives me hope. I was about to quit gaming and throw away my computer. Yesterday saw this post and downloaded config on telegram channel. Placebo or not I had 1.5 kd on warmup dm servers and played 3-4 premier game(im at 28-29 k rating). Everygame i played i hit insane shots which i never had that feeling for 1 year. Before the config i couldnt even shoot back to enemys I was barely getting positive KD. While this config was running at backround my lowest score was 25 kills and that game finished 13-4.
They still ferrari peeks you but with this config i was able to shoot back. Dont know if its placebo or something else fixed on my computer but it did happens after using this thing.
Posted: 18 Dec 2025, 06:15
by yam1ke
Wow, thanks for positive review! Which version of app have you used and which config?
Posted: 18 Dec 2025, 08:15
by DangerAhead710
I wish u had one for valorant bro coz this has helped me in cs as well but I mainly play valorant
Posted: 18 Dec 2025, 08:38
by Lev1n
yam1ke wrote: ā18 Dec 2025, 06:15
Tryed everything you posted on telegram but used 3.5 and custom config you give me.
Posted: 18 Dec 2025, 08:40
by Lev1n
Lev1n wrote: ā18 Dec 2025, 08:38
Tryed everything you posted on telegram but for me best one is 3.5 and custom config you give me.
Posted: 18 Dec 2025, 09:03
by yam1ke
DangerAhead710 wrote: ā18 Dec 2025, 08:15
It works great in Valorant. I have positive feedbacks. Use version 3.6 and config for hitreg with no phantom
Posted: 18 Dec 2025, 12:52
by DangerAhead710
So I just have to rename no phantom as config.ini and then load your app as admin and then let it run in background while I play valorant? That's all? Or are there other changes in the config I have to do?
Posted: 18 Dec 2025, 13:16
by yam1ke
DangerAhead710 wrote: ā18 Dec 2025, 12:52
Yup, nothing more. Just check may be that this app in task manager loads your CPU.
Posted: 18 Dec 2025, 14:18
by rekaa02511
Can you tell us more what this does in the background? I think many people here are sceptical with no information at all.
