Did anyone try using original Windows?
Palacko
Re: Did anyone try using original Windows?
Post by Palacko » 26 Dec 2025, 04:46
You from Microsoft Bro πŸ˜‚ trying to find customers who suffer from Input Lag to buy Windows Key. I know 20 Players nearly 4K Elo never ever activates Windows as it doesnt matter.
NotaBotY2k
Post by NotaBotY2k » 27 Dec 2025, 02:27
Seeing this desync issue boil down to downgrading to an older version of windows is amusing.
I would try it but am stuck to w11. If this seems to fix things then there is a software issue which should be fixable. W11 introduced HAGS and windows VRR, HPET(?), idk. It's hard without benchmarking to see what all reduces latency. It can be a spft bug as well just needing to reset the software, not a hard bug involving bad drivers or protocols.
I was left thinking there's an issue between duka servers/ netcode then the bad Realtek NIC drivers. But the Windows Network stack issues conflicting with drivers was known.
The latest Realtek drivers seemed to fix things but it's hard to chalk it up without dedicated benchmarks.
I was just played Warzone/ BF6 again, other games seem fine.
The theme had been random online gaming had been awful. Private games were the best way to enjoy the games. No progression but if you want keep your own records and clan & company records if you want to get commercial.
These online games are supposed to be dedicated servers which are usually good. I prefer 24-30hz servers, many are 60+ now, which I found affected the TTK (time to kill) and speed of the game itself. But as well client side FPS affecting physics so supposed server side frequency, hz, tick rate, may not control everything. That's going back as far as the origional Quake/ Unreal games, using client side fps to exploit physics.
CoD, Warzone, BF 2042/ 6 broke my spirits though. It's such a horrible experience for so many people.
Console only may also be a way to go with locked frequencies. But then you have mouse & keyboard support, kind of tit for tat with mouse accuracy or controller aim assist. I played Warzone on both XBSX and Ps5, xbox had tight controls, but said to play with pc there was no real console only on ps5 but the controls weren't as good to me.
Then ISP/ Router stuff. I'm plugged direxlty into the modem at 1gbps still having some issues on ethernet or wifi, but wifi seemed to be less questionable over the years with minimal latency. Those realtek drivers just had evident bugs and glitchyness. But I'm defaulted on latest drivers, idk.
They say just leave it defaulted. RSS on/Offloads on, RSS off/ Offloads off, then someone said no leave it defaulted but RSS didn't even seem on ornsupported by the latest drivers or on in windows network. idk
I would do it though, version is a little superfiiscial for me personally, I just want my game to work.
Β―\_(ツ)_/Β―
agstrato
Post by agstrato » 30 Dec 2025, 11:01
donktuman wrote: ↑
25 Dec 2025, 18:20
i have bought it for 160 euro and it did nothing. Call me stupid but i did so you dont need to
Sorry to hear that i believe you just spared me of spending 150 euros. Are you sure it is using the code you bought or does mg activation take over?
agstrato
Post by agstrato » 30 Dec 2025, 11:02
joseph_from_pilsen wrote: ↑
25 Dec 2025, 20:52
I buy win11pro keys for 1.06 euro each. They work fine :lol:
You know im talking about the phisical version of windows the ones that come in a package with a usb.
agstrato
Post by agstrato » 30 Dec 2025, 11:05
MK92 wrote: ↑
26 Dec 2025, 04:17
Well, if you bought original windows AFTER you already activated it with KMS, it doesn't really matter anymore since your PC could already be permanently "infected"...those activators are injecting code directly into CPU and MOBO as rootkis, and even flashing a new BIOS won't erase that, so if the code is malicious it could cause problems forever until you change MOBO.
But this is obviously not a culprit of our problems, like 90% of people doesn't have original Windows.
I believe you don't really know how hwid activation works. I'll keep it short, so basically what it does is that it impersonates your PC as a windows 7 pro and it uses that to free upgrade to windows 10/11. It cannot inject any code into CPU or motherboard because it's not OEM. The rootkits are like a set of backdoors mostly for Linux operating systems, you can think of them as viruses but usually much more advanced. I been around for some time...
darkbebe
Post by darkbebe » 30 Dec 2025, 11:09
agstrato wrote: ↑
30 Dec 2025, 11:02
25 Dec 2025, 20:52
i have the real one dvd & usb version i bought for like 150€. no difference about the hit reg problem due to isp
agstrato
Post by agstrato » 30 Dec 2025, 11:09
Palacko wrote: ↑
26 Dec 2025, 04:46
I just read your message and i find it funny so i'm gonna answer. Yes bro i work for this multibillion dollar company and i am searching for the 0.1% users that have this issue to scam them and make them buy original windows so that daddy Gates and Satya Nadella can buy another yacht to add to their fleet.
Sound about right? Now for the real thing, you know when you have an issue that's pretty much impossible to solve you start and think of everything and test if it's that or not untill you find the answer. I don't know about you but it makes sense to me to just check everything.
agstrato
Post by agstrato » 30 Dec 2025, 11:11
darkbebe wrote: ↑
30 Dec 2025, 11:09
agstrato wrote: ↑
30 Dec 2025, 11:02
25 Dec 2025, 20:52
Interesting, could you upload the .iso of the USB version ? I want to check some things between downloaded and that one. Of course make sure the key is not there in a text or something.
donktuman
Post by donktuman » 30 Dec 2025, 12:03
agstrato wrote: ↑
30 Dec 2025, 11:01
donktuman wrote: ↑
25 Dec 2025, 18:20
yes im sure even reinstalled windows and everything :D trust me im nerdy enough to try everything
agstrato
Post by agstrato » 30 Dec 2025, 13:12
donktuman wrote: ↑
30 Dec 2025, 12:03
agstrato wrote: ↑
30 Dec 2025, 11:01
donktuman wrote: ↑
25 Dec 2025, 18:20
Did you actually checked to see if the reinstalled windows is really using your code ?
