How to set lg c1 run at 60hz bfi for 60fps >60hz input?
Baron of Sun
Re: How to set lg c1 run at 60hz bfi for 60fps >60hz input?
Post by Baron of Sun » 03 Jan 2026, 03:59
1. Tearing can be avoided by using VRR but besides the upcoming Gsync Pulsar you cannot use VRR and BFI simultaneously. If you use BFI, tearing is still a thing. Stutter happens with low framerate or framerate fluctuations which is also independent on BFI. CRT motion on such an LCD is possible despite high GtG response times if the GtG transitions happen during the darkened screen. If the strobing is timed perfectly, motion can be awesome. See the Viewsonic XG2431 discussion.
2. Some PS5 games have internal VSync options. There is no system level option, but I cannot tell if there is an internal system level cap implemented by Sony.
3. If there is no setting on the PS3 for that, it might be impossible to force 30 Hz output.
4. There are videos on YouTube which show that it's rolling scan. Newer LG OLED like the G5 have classic BFI (black full frames between two input frames). Do not confuse the last technique with global strobing from LCD, because OLED have no global backlight.
derekchan
Post by derekchan » 03 Jan 2026, 13:14
Baron of Sun wrote: ↑
03 Jan 2026, 03:59
Do you think flicker free rolling scan of pvm 2541 sony pro oled can reduce 24p stutter?
I watch movie isles of dog and there is a normal speed panning shot has a very noticable stuttering,it will be smooth like 60fps motion if frame interpolate kicks in.
But i hate this way and i am wondering if flicker free of sony pvm can work like frame interpolate.
Also this is a 60hz panel but has two panel frame rate 48hz
derekchan
Post by derekchan » 05 Jan 2026, 02:19
03 Jan 2026, 03:59
may i ask
can i extend oled gtg time ms from 3ms to 10ms to reduce 24p stuttering?
i have a slower gtgms x900e which has better 24p stuttering motion than lg c1
can i suggest a good movie scene to test 24p stuttering but not 3:2 pull down 24p judder?
2.chief said 120hz dlp projector has 8.X ms presistance blur as other sample hold display
but dlp is a non sample hold display ,does it have better motion blur than 120hz non strobe oled ?
3.why lcd vr headset quest 2 and eizo turbo 240 monitor have 0.3ms and 2ms presistance blur?
A 120hz display has 8.xms presistance blur but why quest 2 has 0.3m ,even you strobe 120hz signal you will get 4ms presistance blur
Baron of Sun
Post by Baron of Sun » 06 Jan 2026, 08:46
derekchan wrote: ↑
03 Jan 2026, 13:14
03 Jan 2026, 03:59
Frame interpolation is the only way to reduce stutter and increase motion clarity without flicker.
Baron of Sun
Post by Baron of Sun » 06 Jan 2026, 09:07
derekchan wrote: ↑
05 Jan 2026, 02:19
03 Jan 2026, 03:59
may i ask
1. You cannot extend the OLED GtG times. Because of OLEDs fast pixel response times stutter appears heavier than LCD with slow GtG.
2. DLP projectors are technically strobed, but at very high rates (kHz). As far as I understood, that strobing is only used to adjust the brightness by doing Pulse Width Modulation. It is not the same principle as showing Frame A for 2 ms and then being dark for 6 ms, which would indeed reduce motion blur.
3. VR headsets use backlight strobing (LCD) or rolling scan (OLED) to reduce motion blur because when using a VR headset, it is necessary to have low persistence to avoid motion sickness. This is also why they run at refresh rates higher than 60 (90 or 120), to avoid the perceiption of flicker for lots of people. Of course that is possible on consumer televisions too (like the CX or C1 proved to us), but as lots of people are unaware of the existence of motion blur, manufacturers do not care about implementing rolling scan in modern OLED anymore.
derekchan
Post by derekchan » 07 Jan 2026, 06:56
06 Jan 2026, 09:07
derekchan wrote: ↑
05 Jan 2026, 02:19
03 Jan 2026, 03:59
may i ask
may i ask ...
1.Do you mean lg c2 not using rolling scan to bfi? back to the day i go to the store,the seller advise me to choose c2 but not c1
2.my c1 has a lot black sesame dot at the bottom edge of tv, should i throw it away and pick up a new one?
3.i have a old lcd tv x900e which support strobe bfi too but has slower gtg 10ms time.
Does it have similiar motion clarity with bfi on compared with lg c1 bfi on (3ms gtg)?
4.i test two time to compared c1 and x900e by watching isle of dog.
The fast speed panning camera shot on slower gtg 10ms lcd look more natural to c1.
without frame interpolation i will choose x900e to avoid terrible 24p stuttering on oled.
5.Do you mean 120hz dlp projector has simillar motion clarity as 120hz non bfi oled ?
I guess non sample hold dlp can achive 24p frame hold time as 10ms gtg lcd
6.How could i use software bfi on a non g sync 60hz lcd?
radeko
Post by radeko » 07 Jan 2026, 08:50
use frame generation to achive 120fps . than turn on motion pro medium or high . THATS IT . simple
LSFG
or nvidia smooth motion
or nvidia frame generation or
nvidia multi frame generation
LG C1 55"
derekchan
Post by derekchan » 09 Jan 2026, 00:53
radeko wrote: ↑
07 Jan 2026, 08:50
LSFG
Why standard mode on c1 can enable game optimizer ui like bfi var option
Should I play game on standard picture mode but not game optimizer picture mode
derekchan
Post by derekchan » 09 Jan 2026, 00:54
JimProfit wrote: ↑
30 Dec 2025, 20:50
At 50/60hz, You can only do Motion Pro High. Or at least only that without double-image artifacts.
Auto, Low and Medium only strobe at 100/120hz.
A combination of 120hz Motion Pro (at any setting) + ShaderBeam (2 sub-frames for 60fps content) can potentially look great, since you have enough tools at your disposal to strike the best motion/brightness balance for your content.
Edit: You mean you're having trouble setting the PC output to 60hz?
Maybe it's driver related or something? On my (outdated) NVidia control panel, I know that 60hz is in the top category or resolutions (Ultra HD, HD, SD) and the 120hz mode is buried lower in the "PC" category.
Mai I ask why motion pro bfi can’t solved 24p stutter 41.67ms presistance blur,the panning shot look much better on 10ms gtg lcd but not 3ms gtg lg oled
Baron of Sun
Post by Baron of Sun » 09 Jan 2026, 02:59
derekchan wrote: ↑
09 Jan 2026, 00:53
radeko wrote: ↑
07 Jan 2026, 08:50
LSFG
Game optimizer should be enabled, otherwise you have high input lag which is not nice for gaming.
