I completely fixed desync in online games.
DangerAhead710
Re: I completely fixed desync in online games.
Post by DangerAhead710 » 03 Jan 2026, 00:32
This worked for me for 5-6 days and everything started getting shit again πŸ˜” I tried this fix back in 2023
gideonmontes
Post by gideonmontes » 03 Jan 2026, 00:54
DangerAhead710 wrote: ↑
03 Jan 2026, 00:32
I don't know exactly how your problem manifests itself, so maybe that's not the issue, although hardware issues are worth considering as well. In my case, this is a 100% solution, so I just thought I'd share it on this forum in case it helps someone else.
ablemor
Post by ablemor » 03 Jan 2026, 09:23
do u have floaty mouse too? I think its 90% EMI or ground issue.
and How long has this fix been working for you?
Post by Slender » 03 Jan 2026, 11:33
I think in your case, the current was choosing the path that was causing you problems. You disrupted the "bad" current path by changing the screw resistance.
For a clean experiment, run your setup without the metal case.
donktuman
Post by donktuman » 03 Jan 2026, 13:21
gideonmontes wrote: ↑
03 Jan 2026, 00:54
03 Jan 2026, 00:32
i like how naive you guys are once it works for couple of days :D come back after few months then say its 100% fix :D now it sounds ridiculous
Apexer15
Post by Apexer15 » 03 Jan 2026, 16:24
By "Cooler" you mean the screws that ties the fan itself? πŸ€”
BARGHEST
Post by BARGHEST » 03 Jan 2026, 17:10
Oh my god, what nonsense! If you overtighten the CPU heatsink, it will bend the board and the RAM will fall off. This is the first time I've seen anyone write that you can overtighten the video card. Oh my god, what nonsense. Yeah, right now we're all convinced that as soon as you turn off the PC and try to unplug the hardware, there will be a temporary improvement, TEMPORARY! :D :D :D :D :D :D :D :D :D
gideonmontes
Post by gideonmontes » 04 Jan 2026, 05:39
Okay guys, I don't think there's any point in trying to prove anything to you. Let at least the people who are looking for a solution to this problem check this out.
Unreazz
Post by Unreazz » 04 Jan 2026, 06:34
04 Jan 2026, 05:39
Can u start playing cs2 and show us montage there also ?
ablemor
Post by ablemor » 04 Jan 2026, 08:01
This is a temporary solution, since you only modified the EMI or the path of current and grounding however, after some time the problem will appear elsewhere.
