Game optimizer release for Windows plus obscure CPU setting
Apexer15
Re: Game optimizer release for Windows plus obscure CPU setting
Thank you for replying but I found "cs2" mentioned only twice in the ini file, replaced the first one under Games with "Apex Legends", the 2nd one with r5apex_dx12.exe and still game isn't detected...
Edit: 3rd cs2 found and replaced with Apex Legends as well and still not working
Hyote
You need to get the exact game name right, so in this example:
[Games]
# Process names without .exe that trigger game mode
r5apex_dx12
[r5apex_dx12]
module=r5apex_dx12.exe*, [auto], pcore, disableboost, applyonce
threaddesc=GameThread*, [auto], pcore, applyonce
threaddesc=RenderThread, (auto), pcore
Or probably the easiest method: open the .ini, Ctrl+H, search for cs2 and replace all with r5apex_dx12
Apexer15
Thanks I think it's working now since I see the task bar goneHyote wrote: ↑12 Jan 2026, 17:01You need to get the exact game name right, so in this example:
[Games]
r5apex_dx12
[r5apex_dx12]
DangerAhead710
I did everything but my screen is flashing after opening the game it turns black and then normal desktop and keeps cycling like this back and forth . My task bar is not visible and I used it for valorant
Hyote
This happened to me a few times with Dying Light. Try running the program first then open the game or vice versa. Also try switching between FSO/FSE. I don't play Valorant so it's a testing area now.DangerAhead710 wrote: ↑13 Jan 2026, 00:57I did everything but my screen is flashing after opening the game it turns black and then normal desktop and keeps cycling like this back and forth . My task bar is not visible and I used it for valorant
DangerAhead710
How do I revert the changes it has made to my pc?
Hyote
Sometimes I wonder if people are just trolling with the most stupid questions imaginable. If you aren't then close the program and restart your PC. It doesn't make lasting changes.
- themagic
Best Gamer Optimizer ! Input Lag is 0 now ! Thanks Bro !
Here Proof me playing and testing it !
DangerAhead710
It did make lasting change and that's why I asked this question. My fps reduced around 50 fps.
flow
The risk of running a exe someone on a forum posted -not saying it is bad, but I would never run a random exe as admin on my PC just saying..DangerAhead710 wrote: ↑13 Jan 2026, 07:51It did make lasting change and that's why I asked this question. My fps reduced around 50 fps.
