Persistent “behind the server” feeling in games across multiple PCs & OSes – suspected timing / clock / display pipeline
MK92
Re: Persistent “behind the server” feeling in games across multiple PCs & OSes – suspected timing / clock / display pipe
Of course It is not related to any drivers, what kind of crap is this...people have tried on 10-15 year old computers and it was the same, onboard integrated GPU the same, on Linux the same, Win 7/10/11 all the same, it has NOTHING to do with drivers.
Rezurrect
Hello,Sandy wrote: ↑27 Jan 2026, 02:59The origin of all these problems can be traced back to the time Intel released dual-core processors. Since then, operating systems have introduced a new slicing mechanism. Explaining this issue in detail would be too complex.Rezurrect wrote: ↑25 Jan 2026, 18:06Hello, thank you for your response.Sandy wrote: ↑25 Jan 2026, 08:54All of this is due to the graphics card driver.Rezurrect wrote: ↑21 Jan 2026, 15:57Hi,
I’m looking for help diagnosing a long-standing timing / latency issue that I’ve experienced across many different PCs, laptops, operating systems, GPUs, and ISPs.
This is not traditional lag:
Ping is consistently low (10–15 ms)
No packet loss or jitter
High FPS and stable frametimes
Issue is consistent offline vs bots as well
Yet gameplay feels temporally delayed, as if my client simulation is behind the server or behind reality.
Symptoms:
In games like Rocket League, Fortnite, Roblox, Rivals:
Opponents reach the ball first even when I’m visibly closer
I get demo’d / hit after I’ve already jumped or moved
50/50s feel unwinnable
Issue persists even vs bots (e.g. Nexto in Rocket League)
App cold starts on Windows (Explorer, Chrome, Discord) consistently take 5–10 seconds even on fast NVMe systems
Gameplay never feels “correct” or aligned
Critical observations:
Playing remotely on a friend’s PC (remote control / screen share) feels correct and responsive
Cloud gaming does not fix it
One older HP EliteBook laptop worked perfectly
Fedora Linux improves the issue noticeably (especially with gamescope), but does not fully eliminate it
Proxmox + Windows VM did not fix it
Moving the same SSD:
Works fine in a laptop
Immediately has the issue in my desktop
Works fine again when returned to the laptop
This strongly suggests a platform-level timing issue, not OS corruption.
Hardware / OS scope
My Current PC Specs: I5-12400F, 32GB DDR5 4800, AsRock H610M-HDV/M.2, Corsair RM750e, Samsung 980 NVMe, RX 9060XT 8GB.
Tested across:
CPUs: Intel i5-12400F, i9-12900F multiple laptop CPUs
GPUs: RX 580, RTX 2070 Super, RTX 3080, RX 5700 XT, RX 9060 XT
Motherboards: Gigabyte B550, ASUS B760M, ASRock H610M
RAM: DDR4 & DDR5
Storage: multiple NVMe & SATA SSDs
PSUs: Corsair RM750e, CV550
Monitors: Alienware AW2521HF (240 Hz), BenQ Zowie
Ethernet only, multiple NICs, 8+ ISPs
OS tested:
Windows 10, Windows 11, Windows Server 2022, LTSC
Custom / stripped Windows ISOs
Fedora Linux (best so far)
Proxmox (Linux host + Windows guest)
What I’ve already ruled out
ISP / routing issues
IPv6, VPNs
Peripherals
GPU drivers (many versions)
BIOS defaults vs tweaked
C-states, SpeedShift, ASPM, turbo on/off
HPET on/off
Timer tools (ISLC, timer resolution tools)
MSI vs legacy interrupts
DPC latency problems
Current suspicion
This feels like a clock / timing coherence issue, possibly involving:
TSC / QPC instability
Power management affecting clock determinism
Display pipeline buffering (DWM / scanout timing)
Scheduler / compositor behavior
The fact that Fedora + gamescope improves consistency suggests Windows display & timing layers may be amplifying an underlying platform problem.
I’m not looking for generic tweaks or reinstall advice — I’m trying to understand why client timing is consistently late and how to force deterministic timing / scanout.
Any insight from people familiar with:
input lag vs scanout lag
frame pacing vs simulation timing
OS clock behavior
display pipeline latency
would be hugely appreciated.
I've tried multiple GPU driver versions, including searching up multiple best stable driver versions for both AMD and Nvidia GPUs when I've had either one, and nothing fixed it.
In short, don't waste your time elsewhere. Try using a 3060 graphics card with driver version 552.22. You can try this combination; some old-school gamers who experience no input lag recommended this perfect graphics card and driver combination to me (it must be a 3060, not a 3060Ti). However, brand new 3060 graphics cards are no longer available; only used ones can be found on the market. The good news is that Nvidia is preparing to restart production of the 3060.
Thank you for your response.
I am not sure if it's just terminology, but I don't have input lag, or any visual lag. But the feeling like I am behind the server even with really low ping, no jitter/packet loss with Ethernet gig speed connection. I've heard the word desync be used for this kind of issue a lot. I believe I have tried that driver version previously (not with a 3060), but a 3080, and no matter the driver version, it didn't do anything.
I'd put it down to my internet, but I have had other devices run perfectly fine. I just don't fully understand how this happens.
Sandy
You can try using the 552.22 graphics driver without a 3060 graphics card. This costs nothing and there's no downside. Use DDU to uninstall your current graphics driver.Rezurrect wrote: ↑27 Jan 2026, 07:54Hello,Sandy wrote: ↑27 Jan 2026, 02:59The origin of all these problems can be traced back to the time Intel released dual-core processors. Since then, operating systems have introduced a new slicing mechanism. Explaining this issue in detail would be too complex.
Rezurrect
Hello,Sandy wrote: ↑28 Jan 2026, 03:29You can try using the 552.22 graphics driver without a 3060 graphics card. This costs nothing and there's no downside. Use DDU to uninstall your current graphics driver.Rezurrect wrote: ↑27 Jan 2026, 07:54Hello,Sandy wrote: ↑27 Jan 2026, 02:59The origin of all these problems can be traced back to the time Intel released dual-core processors. Since then, operating systems have introduced a new slicing mechanism. Explaining this issue in detail would be too complex.
I would if I could, but I just recently got a brand new 9060xt.
akylen
Got the exact same problem for years and still no solution at this day, so it is working fine on your laptop ? can you describe the specs if yes ? thanksRezurrect wrote: ↑21 Jan 2026, 15:57Hi,
Symptoms:
Hardware / OS scope
Tested across:
RAM: DDR4 & DDR5
OS tested:
IPv6, VPNs
Peripherals
HPET on/off
Current suspicion
OS clock behavior
Sandy
If you've already tried everything else, then you might as well give it a try.Rezurrect wrote: ↑28 Jan 2026, 03:54Hello,Sandy wrote: ↑28 Jan 2026, 03:29You can try using the 552.22 graphics driver without a 3060 graphics card. This costs nothing and there's no downside. Use DDU to uninstall your current graphics driver.Rezurrect wrote: ↑27 Jan 2026, 07:54Hello,Sandy wrote: ↑27 Jan 2026, 02:59
Rezurrect
Hello,akylen wrote: ↑29 Jan 2026, 18:41Got the exact same problem for years and still no solution at this day, so it is working fine on your laptop ? can you describe the specs if yes ? thanksRezurrect wrote: ↑21 Jan 2026, 15:57Hi,
Symptoms:
Hardware / OS scope
Tested across:
RAM: DDR4 & DDR5
OS tested:
IPv6, VPNs
Peripherals
HPET on/off
Current suspicion
OS clock behavior
Sorry for the delayed response, have been on holiday.
Yeah still no solution. I have had a couple of laptops that ran fine, an old hp elitebook i5-6300u and an old i7 7th gen 1050ti laptop (This one would only work fine after reinstalling windows on first boot, idk why, so I was reinstalling windows everytime I wanted to play games). I had a pc a while back that also didnt have the issue, it was an asus rog ga15 1660ti 3600x.
One weird thing I forgot to mention (I think), is that I had a touch screen laptop for work, but would use for games at times (cant remember the laptop or specs), but when you left touchscreen on in device manager, games ran fine, but when you turned it off, the delay would happen.
Yeah its seriously weird...
I wish I could explain more but it confuses the sh outta me lmao.
Rezurrect
Hello,Sandy wrote: ↑30 Jan 2026, 05:36If you've already tried everything else, then you might as well give it a try.Rezurrect wrote: ↑28 Jan 2026, 03:54Hello,Sandy wrote: ↑28 Jan 2026, 03:29You can try using the 552.22 graphics driver without a 3060 graphics card. This costs nothing and there's no downside. Use DDU to uninstall your current graphics driver.Rezurrect wrote: ↑27 Jan 2026, 07:54
Hello,
Sorry for the delayed response, I was on holiday.
I am confused at what this means, I won't be able to install an nvidia driver as I have a amd gpu now, and no longer have access to an nvidia gpu.
Rezurrect
Hello,
Just a follow up.
Has anyone found any potential fixes? It's getting really annoying playing games since things just aren't fun at all. I'm not expecting to be pro level in any sorts, but it's impossible to play games without being bs'ed on every game. I'm not even sure what to do anymore.
Just a follow up.
akylen
Currently no solution except for somes this is to move out, recently we got a fun fact https://www.reddit.com/r/GlobalOffensiv ... /?sort=new
Twistzz said in the video on the computer at the tournement the models of the ennemies was skipping. So let just pray it'll lead to something.
