Page 2 of 2
Re: Strobe Crosstalk Issue on XL2586k+
Posted: 12 Mar 2026, 22:22
by tchomes
kyube wrote: ↑
12 Mar 2026, 08:58
tchomes wrote: ↑
12 Mar 2026, 01:21
Yea I did read that and 500hz works great! But I wanted the extra smoothness because I've been truly spoiled.
Are you able to sustain +600FPS in the games you play?
I believe going to a lower refresh rate value for the less crosstalk benefit & easier frame rate value to run is a "hit two birds with one stone" situation.
tchomes wrote: ↑
12 Mar 2026, 01:21
I've tried to align crosstalk with the 2.0.9 utlilty but it didnt seem to have any effect on this monitor. Even trying random values in softMCCS had no effect either.
Yep, Dyac2 is not functional with the Blurbusters utility anymore... They've seemingly removed the VCP commands..
tchomes wrote: ↑
12 Mar 2026, 01:21
Hi Kyube
I can only find 599.91hz at the lower 1280x960 resolution. Any attempts to get 1080p to take 599.91 in CRU, whether in Display 1.3 or 2.0, results in it only allowing for 599.94hz
--snip--
Please see the reply I made to Chief on still images of the video I took of the crosstalk test. I've tried altering the same settings on both HDMI 2.1 and DP 1.4 cables
Try playing around with the Front/Back Porch, Blanking.
Perhaps fixing the refresh rate to 599.91 in CRU would help? But I don't think the actual value is what drivers the lower crosstalk behavior
I ended up following witega's post viewtopic.php?t=14300 about "Exact Reduced" timings in CRU and resolved my crosstalk misalignment issue.
