Reasons to switch back to BenQ FastTN?
kyube
Re: Reasons to switch back to BenQ FastTN?
Post by kyube » 11 Jul 2026, 06:54
MSIfanboy wrote: ↑
10 Jul 2026, 19:53
--snip--
The XL2586X should have the highest voltage amplitude & thus the best brightness, even on its most aggresive setting (DyAc2=Premium)
I am impressed by the PG248Q@500Hz & surprised by how much artifacting the XL2586X has at 500Hz.
Thank you for the UFOs!
They're all definitely 1px/s, which means it's at least ≤25% pulse width on their best modes :D
What PW setting did you use on the PG248QP?
j1ffrey wrote: ↑
10 Jul 2026, 20:28
What about AMA? I currently use high bc I think it has less overshoot than premium. I also have a custom setting for AMA which is a slider from 0-30.
Also is there a way to change the position of the "crosstalk band" I think it's called? I did that with the strobe utility on my old XL2546 but last I remember trying the strobe utility didn't work with X model.
I don't have the data on which AMA is the best for the XL2546X.
You'll have to rely on your own eyesight in that regard :D
Crosstalk is a byproduct of slow G2G RT.
You aren't able to adjust the region in which crosstalk appears on DyAc2 displays, as far as I know.
