⚡Potential fix for desync, input lag, floaty mouse, heavy car bug, etc.⚡
naporitan
Re: A possible fix or solution to the mystery of the problem
Post by naporitan » 24 Jul 2026, 14:46
ablemor wrote: ↑
24 Jul 2026, 14:35
try to play in fullscreen windowed mode
Why? You need to use fullscreen mode in games.
naporitan
Post by naporitan » 24 Jul 2026, 14:58
LaggyTyp wrote: ↑
24 Jul 2026, 03:07
Interesting.
I’ve been complaining for years about having desync and hit-reg issues while gaming (e.g., in Battlefield). It’s not a network or internet issue; it’s a local problem that simply cannot be fixed.
I just tried out the Dino game, and I can clearly see it speeding up.
The interesting thing is: when I play BF6, the game runs normally at first, but minute by minute, the opponents get faster and faster. I barely have any time left to react. My window for reaction shrinks. The worst gamers in the world start playing like pros.
The Dino game fits this pattern (the problem) perfectly.
Yes, you got it right.
Hyote
Post by Hyote » 24 Jul 2026, 15:01
I'm not going to disprove this information but I have to add that it's a very one sided perspective you always push. If the Dino game can be used as a benchmark then I can just hop on with my patched QPC driver which makes everything extremely slow and get a highscore with that. The same way you could benchmark aim400kg with someone playing normally or another person using a color triggerbot and just having to move on the targets. PCs need optimization because there is room for them. And default Windows and browsers have so many anti-consumer elements that it sounds insane not to optimize them.
TN_fun
Post by TN_fun » 24 Jul 2026, 16:32
Is it just me, or is the screen resolution different between the dino video clips showing the problem and the ones without it?As for optimization—anyone can optimize whatever and however they want; that’s their personal choice. But in any case, on properly working hardware (I don't know, and nobody knows, why it works fine for some and not for others), a clean Windows installation without any tweaks will never cause desync. I repeat—never.Regarding everything being said here: there might actually be a key to solving the problem. If everything runs flawlessly on a laptop with zero desync while the Secure Boot settings are hidden, then PC desync might be linked to these exact settings.Before reinstalling Windows, you need to clear the TPM keys in the system, restart, enter BIOS, and clear the TPM keys there too. Only then should you install Windows. I don't think this will fully fix the issue, but it should keep the system synchronized for a longer period of time.
naporitan
Post by naporitan » 25 Jul 2026, 11:16
Slender wrote: ↑
24 Jul 2026, 19:11
я читал твои старые сообщения на других форумах и раньше ты был более рассудителен. наверное ты просто устал.
https://www.twitch.tv/ct0m/clip/Correct ... U3FJKLwL8t
Babluga
Post by Babluga » 25 Jul 2026, 13:24
"The longer the run lasts, the faster the pace and the harder it gets." :D
naporitan
Post by naporitan » 25 Jul 2026, 13:45
Babluga wrote: ↑
25 Jul 2026, 13:24
In this topic, I posted a video demonstrating that there is abnormal acceleration on faulty systems.
I also demonstrated how the run should proceed on a properly functioning system.
viewtopic.php?t=15638#p126435
viewtopic.php?t=15638#p126436
naporitan
Re: ⚡Potential fix for desync, input lag, floaty mouse, etc.⚡
Post by naporitan » 26 Jul 2026, 04:36
:!: Updated some information in the thread.
naporitan
Post by naporitan » 26 Jul 2026, 07:22
https://kz-rush.ru/ru/forum/topic/223/
On a working system, it is possible to upgrade Ruby on KZRush with a 250 ping.
ablemor
Post by ablemor » 26 Jul 2026, 08:06
naporitan wrote: ↑
24 Jul 2026, 14:46
ablemor wrote: ↑
24 Jul 2026, 14:35
Because the render is different, and for anyone struggling with floaty mouse movement, it might help, mouse movement might change slightly because of DWM, it can become a bit more consistent.
Locked
