jassine wrote: ↑10 Sep 2026, 13:17
I tried iperf3 and here are my results, they look ok but the desync issue is killing me (behind server feeling)
thank you for posting your result. I assume you are on a cable plan (coax) looking at your values? am i correct?
Honestly if you are on Fiber those values are not very good, for coax cable they are okayish. IMO on fiber you should be below 0.050ms UDP jitter anything higher means something sus is going on especially on a 10mb load...
chipotlechicken wrote: ↑11 Sep 2026, 01:52
Do you experience UDP jitter with perfect waveform bufferbloat scores?
If thats measurable than sure I have no issues acknowledging it can cause issues.
But not everything is network related, you just need to fix your network so you can fix what else is messing with your system.
Fixing my network first was a funny experience because I got to feel my system's lag without my network lag, and although it's impossible to figure out which ones which when both are happening simultaneously, when one is isolated it does show different behavior.
It was like having training weights on every since one of my movements. But the hitreg was still okay.
But anyways im curious as to how you are having network issues with your fibre connection with a perfect bufferbloat. Are they putting you on CGNAT?
No i'm not behind a CGNAT and i don't use any smart queue management algorithm. Yes i experience more jitter on the provider with better bufferbloat because it has a weaker BGP and uses worse routes. You can have a perfect bufferbloat score, if the route your ISP use is oversaturated it will be more jittery anyway; that is why i recommended you to look for a tool called "Looking Glass" in the first place.
So essentially UDP and TCP are handled totally differently by ISPs. You can have TCP bufferbloat (waveform bufferbloat) without affecting UDP, because some ISP put higher priority on UDP. Not always the case of course. Most treat both protocols the same way.
Some even encapsulates IPv4 into IPv6 (hello Germany and USA) which is good for security but an absolute horror show for online gaming because it causes MTU mismatches and higher overhead + added latency.
Some countries also use deep packet inspection (Ukralne, Turkiye, Poland and others that i can't recall right now), which add another layer on top... Most ISP under "Liberty Global" also used deep packet inspection at a certain point, not sure if they all still do nowadays.
I mean it's case dependent really, you have to thoroughly test each ISP independently over tons of things and see, because after all it depends how it's handled in their infrastructure. In your case it might be that your ISP was treating UDP and TCP as "same priorities", which is very common nowadays unfortunately; so fixing your bufferbloat also fixed your UDP shenanigans hence why it feels better for you.
Also, I recommend you to do some research on "IP pools" for your particular ISP. Some IP ranges get shorter routes than others. the easiest way to do it if you have no Looking Glass at hand is like this: take about 5 IP addresses for reference do a winMTR for each and save each result. Turn off-on your modem or lauch a new PPPoE session -- to get another IP address in a different pool -> meaning if your first adress is lets say 61.XX.XXX.XXX try to get a number that is far from that for example : 128.XXX.XX.XXX you will be in another IP range.
Obviously ISPs have many datacenters so by getting an IP from another range you will most likely route your packets from another Point of Presence. Then use the 5 IP addresses of reference in winMTR and check the result. Same result? Try to get another IP rinse and repeat until you get an IP that routes packets differently.
