OC x-star 27 inch monitor [how to overclock to 120Hz?]
Re: OC x-star 27 inch monitor [how to overclock to 120Hz?]
Post by Chief Blur Buster » 15 Jan 2014, 18:05
swardmusic wrote:ok. how do i go about doing that? do u have a link u could share? cheers
Changing from "Auto" to "Manual" in your Custom Resolution Utility, and then manually tweaking the numbers, such as making the Porches/Sync smaller, in order to achieve higher refresh rate with lower bandwidth (lower dotclock) to attempt to reduce artifacts.
This is an advanced tinkering step, but I don't think it's worth the effort if you're already getting flawless 108Hz.
