Does G-Sync fix issues that V-Sync typically does.
Joolsyz
Re: Does G-Sync fix issues that V-Sync typically does.
Doesn't work as well as V-Sync? In some games it most certainly does.
Black Octagon
REALLY?! What games? And at what points?MxOAgentJohnson wrote:After buying a gsync monitor i can confirm G-sync does not hide stutters in games at points where vsync would. So there we go, the lack of tearing and the smoothness of fluctuating fps is amazing but doesnt work aswell as vsync so take from that what you will anyone who google searches
MxOAgentJohnson
Half Life 2, borderlands 2, dishonoured, Far cry 3 hates Gsync same as RAGE and a few more,.Black Octagon wrote:REALLY?! What games? And at what points?MxOAgentJohnson wrote:After buying a gsync monitor i can confirm G-sync does not hide stutters in games at points where vsync would. So there we go, the lack of tearing and the smoothness of fluctuating fps is amazing but doesnt work aswell as vsync so take from that what you will anyone who google searches
Joolsyz
MxOAgentJohnson, don't happen to have a copy of Crysis 3 do you? Reason I ask is because I found this to work pretty well with g-sync apart from the one level "Welcome to the Jungle", doesn't matter what the frame rate is it stutters and hitches like crazy but every other level is perfectly smooth.
MxOAgentJohnson
Sorry man only own Crysis 2 and 1Joolsyz wrote:MxOAgentJohnson, don't happen to have a copy of Crysis 3 do you? Reason I ask is because I found this to work pretty well with g-sync apart from the one level "Welcome to the Jungle", doesn't matter what the frame rate is it stutters and hitches like crazy but every other level is perfectly smooth.
