Have you seen the XL2730Z's service menu, though?
It seems to have the same service menu as the Asus VG27HE.
You can actually adjust OVERDRIVE GAIN in it.
On VG248QE, you can use this to adjust overdrive in Lightboost mode!
http://forums.blurbusters.com/viewtopic.php?f=13&t=2012
So that means on XL2730Z, you can adjust overdrive settings (besides AMA high/premium/off) in benq BR mode by going through the service menu?
And someone needs to find out if VT Tweaks work on this thing!!!!! (Poster in that thread wasn't using pixel clock patcher so that 430 MHz pixel clock was probably discarded...)
XL2411Z AMA settings with BR=ON
Falkentyne
Return to “BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — BFI / ULMB / ELMB / DyAc / framegen / LSS / etc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory: Display Science Section
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
