I have the newest nvidia drivers, how I can unlock lightboost with this?Falkentyne wrote:Strobelight will not work on any Z series monitor. It can control LB settings once LB has been unlocked, but it can not unlock it. Strobelight can only unlock lightboost on older lightboost monitors (XL2411T, 2420T, 2720T, 2420TE, VG248QE, but not 2430T). You will need the INF/Nvidia drivers to unlock Lightboost mode.
xl2411z vs ??
alpen
Re: xl2411z vs ??
Falkentyne
Re: xl2411z vs ??
The best way is with the INF override method and editing the "VG27H" ID into toastyx's custom resolution utility. There should be a "how to#2 and #3 on the main blur busters' site which should tell you how to unlock Lightboost mode.
I don't have an desktop Nvidia card so I can't help. I used the INF override plus the "3d vision emulator" on my NVidia laptop to unlock 3d lightboost (using a DVI to HDMI adapter, not easy to do since I had to output a 'non supported' 120hz HDMI signal at a frequency not usually allowed through HDMI (but got a display since the monitor itself was set to DVI).
I don't know if the 3d vision emulator still works. Someone said it stopped working on Nvidia 311.xx+ drivers.
alpen
Re: xl2411z vs ??
if I take persistance to max brigthness in strobe utility and play on blur reduction(xl2411z) I will have better effect in csgo, than without blur reduction?
