are you usign isntant mode?
http://www.tftcentral.co.uk/images/benq_xl2720z/lag.png
Weird input lag?
br00m
Re: Weird input lag?
I know this is really old and nobody is going to read this but since i hopped into CSS for an hour and played csgo again i could feel the input lag in csgo. I guess its just bad gamecode but if anyone knows a fix id gladly aappreciate it.
- RealNC
Disable vsync and don't play in windowed mode. Use exclusive fullscreen. Force vsync off in the driver to be sure. Don't use ANY command line options. "-novid" and "-freq 144" are the only ones you can use. Don't use any autoexec commands that "tweak" performance. Just fps_max and rates.
If you messed up your game with idiotic console and startup commands, you need to delete everything and let the game create clear new config files. If you don't know how to do that, then I'm sorry. Don't touch things you don't understand.
