I want to try this with an AMD GPU. I have the exact same monitor and on display port as well. I was using 1728 * 1080 at 144HZ for CS:GO up until now.
Can you post a screenshot of your CRU settings for the highest resolution you managed?
XB240H Overclocks to 198 Hz!
johnsushant
Re: XB240H Overclocks to 198 Hz!
I tried using the timings you listed with CRU. I instantly get "Input not supported".
Also, my resolutions automatically seem to scale to full screen. Even at 800 * 600.
johnsushant
I would also like to confirm if you have the XB240H(no G-Sync) or the XB240HA since the information screen on my monitor looks different.
click4dylan
I have the HA with gsync.
My monitor NEVER says input not supported, on ANYTHING! it just goes to a black screen and then standby. I purchased it refurbished from ebay about 6 months ago
