ViewSonic XG2530 enters 240Hz eSports monitor market
Re: ViewSonic XG2530 enters 240Hz eSports monitor market
Post by RealNC » 20 Jun 2017, 13:27
Chief Blur Buster wrote:I wonder if SMPlayer works with variable-framerate H.264 videos.
It's mpv. SMPlayer is just a front-end (it wraps around the mpv window basically to offer more UI options.)
It does support variable frame rate video, but I suppose nobody actually tested per-frame variable frame rate. Are there even any such test videos out there? I can't find anything.
VS_PM
Manufacturer
Post by VS_PM » 16 Jul 2017, 21:57
Hey Guys,
ViewSonic PM here. I headed the XG2530 project. If you have any questions etc. feel free to ask them here and I'll get back to you as soon as I can. Thanks!
VS_PM
SoulJamboree
Post by SoulJamboree » 08 Sep 2018, 20:09
VS_PM wrote: I headed the XG2530 project.
VS_PM
Current XG2530 owner here - great product and affordable price point.
I notice blurbusters list that this monitor has a blur reduction technology available " via service menu" - can you explain how I activate this setting?
Note: This information was found halfway through the table on this page: https://www.blurbusters.com/faq/120hz-m ... lightboost
Edit: I now understand this may just be the overdrive ie "rampage response" setting. I see guides recommend leaving this as the middle setting "faster" but I am noticing literally no difference in the https://testufo.com/ghosting image between lowest and highest settings (at 240hz 1080p). Could anyone advise what I would see with "perfect" motion blur elimination? I assume that what I would see in the moving image is exactly what I would see in the paused ie stationary image: no thick black outline to the UFO, and 3 clear dots within each UFO segment.
Am I thinking about this the right way?
Thanks for any and all assistance.
Post by RealNC » 09 Sep 2018, 08:50
SoulJamboree wrote: I notice blurbusters list that this monitor has a blur reduction technology available " via service menu" - can you explain how I activate this setting?
No. Blur reduction refers to a backlight strobing mode. Overdrive is something completely unrelated.
SoulJamboree
Post by SoulJamboree » 19 Sep 2018, 03:32
[/quote]
No. Blur reduction refers to a backlight strobing mode. Overdrive is something completely unrelated.[/quote]
Thanks for the reply - any idea what setting the original article was referencing then?
Post by Chief Blur Buster » 19 Sep 2018, 08:11
SoulJamboree wrote:what setting the original article was referencing then?
Link please? Thanks!
SoulJamboree
Post by SoulJamboree » 22 Sep 2018, 14:12
