Glad you love the 240Hz upgrade!eZen wrote:I just received the monitor and it's a beautyyyyy i've been playing with for a few hours now.
The 240Hz experience is kind of surprising, it's of course not as insane as a jump from 60Hz to 144Hz but i can definetely tell the difference.
Many websites frequently say 240Hz is not worth it, but we know better around here.
Other forum members have done a good job at following up on the pros/cons of the AMA settings. It's very user-preference based. The middle setting is the most common setting.
There is a factory reset feature, but I'm not 100% currently sure if it also applies to the OD gain settings. (I currently do not have the XL2546 in hands). One easy trick is to take a smartphone photograph of all the OSD screens, before changing your settings. Go through all the menus, take a picture of each screenful of settings.
