Page 2 of 2
Re: BenQ Zowie XL2540 (UPDATE, it coil whine?)
Posted: 16 Jan 2018, 13:37
by Maxe
elements wrote:Update: I've been using the benq zowie xl2540 for the last week and love it. While testing the blur reduction, I decided it was not as necessary as I first thought.
I have a small problem that may require me to return the monitor, though. It makes a whine whenever it is at 144hz and above, 120hz is near enough silent. This is at factory settings and after I change the colours etc. I've tried creating 239hz resolution etc without any success. Is there any way I can fix this? or should I return it?
I got the XL2546 yesterday, it has the same thing... whine above 144hz. In the process of returning it.
Re: BenQ Zowie XL2540 and XL2546
Posted: 13 Jan 2026, 18:10
by DV2FOX
What did you guys ended up doing?
