If you like "round numbers", I'd see if you can get 103Hz, just so that you get use a 100FPS limit. No reason for it other than "100" sounding better than "97"
Notebook display OC from 75Hz to ... ?
- RealNC
Re: Notebook display OC from 75Hz to ... ?
90 is what I use most of the time. There's no reason for it other than it makes 30FPS video cut-scenes not stutter. But other than that, 3FPS below max Hz should work just as well.
