JOLED to develop high-end OLED gaming monitors
Notty_PT
Re: JOLED to develop high-end OLED gaming monitors
Post by Notty_PT » 23 Jan 2019, 09:28
Chief Blur Buster wrote:
Notty_PT wrote:I want this monitor badly. I still have a CRT that does 100hz at certain resolutions and the moving objects are clearer than any 240hz TN!
Unless you have a variable-persistence strobed TN that stays bright at 0.25ms MPRT.
1. Get a bright adjustable persistence strobe backlight. Such as 240Hz GSYNC(w/ULMB) or 240Hz DyAc
2. Use huge headroom "Hertz-below" strobed Hz for lower strobe crosstalk (e.g. 100Hz or 120Hz strobed on a 240Hz panel)*
3. Slightly bump the digital black level upwards slightly (in NVIDIA Control) to reduce ghosting crosstalk
4. Now you've got near zero strobe crosstalk (Above Average, near undetectable, in Strobe Crosstalk FAQ)
5. Adjust strobe width (either ULMB Pulse Width or BenQ Strobe Duty) downwards to one-quarter original setting.
6. Now I can perfectly read the street names on TestUFO Panning Map Test at 3000 to 4000 pixels/sec on my TN!
You cannot do that with normal ULMB / ELMB / DyAc at default settings.
And it beats CRT in motion clarity.
Well. Some of them. At least the Sony FW900 CRT. Try that panning map readability test on a Sony FW900 CRT (medium-persistence phoshpor), it begins to fail at slower motionspeeds than the best variable-persistence strobe-backlight TNs.
Yes, the CRT has better colors, better blacks, but the TN motion clarity beats CRT if instructions are followed correctly when you have a fine-tuned variable-persistence strobe backlight. Reducing a 1ms MPRT 300nits will reduce nits to 75nits during 0.25ms MPRT, so you do lose a lot of brightness, so it's a brightness tradeoff, and that's why you need one of the brighter strobe backlights. I've even gotten as low as 0.1ms MPRT (but too dark picture)...
*Note: If using non-ULMB, use the Large Vertical Total tricks too, see Appendix A of Crosstalk FAQ
Adjustable persistence dates back to the LightBoost 10% trick days. The strobe width follows Blur Busters Law darn near exactly (1ms strobewidth = 1ms of motion blur per 1000 pixels/sec). Which means 0.25ms flash only generates 1 pixel of motion blurring at 4000 pixels/second motion.
I get severe eye strain with strobing and I dont like the fact it adds input lag aswell, at least on the units I tried so far.
Post by Chief Blur Buster » 24 Jan 2019, 05:19
On that note, OLED rolling scan is more similar to CRT than global-flash like a strobe backlight. This might be easier on your eyes (in addition to being more lagless than global-strobe backlights).
Notty_PT
Post by Notty_PT » 24 Jan 2019, 08:04
Chief Blur Buster wrote:On that note, OLED rolling scan is more similar to CRT than global-flash like a strobe backlight. This might be easier on your eyes (in addition to being more lagless than global-strobe backlights).
Yes! And considering my personal points I recently wrote about 240hz, this oled 144hz is something I will keep my eye on for sure. Fingers crossed for an european release and a fair price. Altho I k ow it will be expensive, but we are enthusiasts after all!
MatrixQW
Post by MatrixQW » 24 Jan 2019, 10:55
Q83Ia7ta wrote:
MatrixQW wrote:Can we speculate how much an OLED 22'' 1980x1080p 120hz could cost?
What would be an acceptable minimum price?
Upcoming Lenovo Legion Y27gq (27" TN 0.5ms 1440p) will cost $999... I guess OLED 22'' 1980x1080p 120hz could cost 1-1.5k or more if will come from gaming brands.
No idea if that is a fair price but considering an Oled TV 55'' costs 1500€, i expect 22'' will be cheaper than 1000€, less size less manufacturing costs.
People are used now to 27'' so i don't know how they would go back to 22'' paying more than 1000€.
I'm fine with 24'' and 22''.
Notty_PT
Post by Notty_PT » 24 Jan 2019, 11:08
I am defo fine with 22 inches aswell! In fact is my favourite size for competitive gaming as my eyes do 0 effort to spot everything at the edges (similar to curved panels effect). Anything bigger than 24 inches to me is a no go. I had ultrawides, had 27 inches , 25 inches. They are all too big for me and affect my gameplay and eye strain (I am very sensitive to eye strain, I can´t even use strobing for 10 minutes).
nuninho1980
Post by nuninho1980 » 25 Jan 2019, 10:26
nuninho1980 wrote:Will JOLED be similar to CRT technology at 50/60 Hz of refresh rate for flicker effect?
Probably not at 60Hz. Only in impulsed mode.
My anticipation is OLED will remain a purely sample-and-hold (flickerless) except for an optional ON/OFF blur reduction (impulsed / rolling scan) at 120Hz+ for future gaming monitors. I do encourage manufacturers to include this mode for 60Hz, and let users decide between flicker (low blur) versus sample-and-hold (more blur but flickerless).
See OLED Motion Blur FAQ
Thank you but I'm not interested JOLED because at 50 and 60 Hz JOLED can't enable implusion (flicker) mode! :/ I stay CRT monitor during next years...
RAM: 2x16GB DDR4@3600MHz
MB: MSI PRO Z690-A DDR4
GPU: Zotac RTX 4090 non-OC <3 :D
HDD: SATA 1TB
PSU: AEROCOOL 1kW 80+ Gold
Disly: ACER Predator XB273U F5 !NEW! :mrgreen:
Notty_PT
Post by Notty_PT » 25 Jan 2019, 13:24
Why you want strobing at 60hz VS no strobing 144hz?
nuninho1980
Post by nuninho1980 » 26 Jan 2019, 05:12
Notty_PT wrote:Why you want strobing at 60hz VS no strobing 144hz?
50 Hz is for PAL TV/youtube and 50 fips*/fps video files. 60 Hz is for most games (SEGA, Konami...), emulators, youtube and 60 fips*/fps video files.
1024x768@85Hz is for desktop, browser, photos, texts...
* - frames interlaced per second.
I don't care 70 Hz or faster because the cons are CPU (and single top-end GPU) bottenecked, most games of 60 fps capped, more PC power/heat and the lifespan of CRT degraded. ;)
HDD: SATA 1TB
Post by Chief Blur Buster » 26 Jan 2019, 22:01
There are use cases.
Even Low-Hz strobing has less motion blur than even 240Hz.
Blur Buster's Law
"1ms of pixel visibility time (persistence) equals 1 pixel of motion blur per 1000 pixels/second"
(For more detailed math and animations, plus links to papers, see 1000Hz Journey article)
Non-strobed displays (where GtG isn't the limiting factor to the refresh rate)
60fps at 60Hz = 1/60sec motion blur ~= 16.7ms = 16.7 pixels of motion blur at 1000 pixels/sec
120fps at 120Hz = 1/120sec motion blur ~= 8.3ms = 8.3 pixels of motion blur at 1000 pixels/sec
240fps at 240Hz = 1/240sec motion blur ~= 4.2ms = 4.2 pixels of motion blur at 1000 pixels/sec
480fps at 480Hz = 1/480sec motion blur ~= 2.1ms = 2.1 pixels of motion blur at 1000 pixels/sec
Strobed displays, any refresh rate, as long as framerate equals refresh rate (e.g. VSYNC ON)
8ms flash per unique frame = 8 pixels of motion blur at 1000 pixels/sec
4ms flash per unique frame = 4 pixels of motion blur at 1000 pixels/sec
2ms flash per unique frame = 2 pixels of motion blur at 1000 pixels/sec
1ms flash per unique frame = 1 pixels of motion blur at 1000 pixels/sec
See.... You only need 1ms flash ULMB VSYNC ON perfect FPS=HZ, to match the motion clarity of a 1000Hz display*
(*with some caveats, read below)
As a result, strobed VSYNC ON is a much easier way to reach those "diminishing points of returns" than ultra refresh rates. It does have more stroboscopic effects, but motion clarity of TestUFO is exactly the same. Remember, persistence is pixel visibility time, you can use shorter frames or do strobing to reduce pixel visibility time. The motion blur math is the same.
Strobe crosstalk (see FAQ) gets worse at higher Hz, so lowering the refresh rate well below maximum can massively improve strobe quality. A compromise strobe frequency is approximately 85Hz or 100Hz. Not as flickery as 60Hz, but not as strobe-crosstalky at 240Hz.
That's why we sometimes like 1ms-flashed 60Hz strobed displays. Though 60Hz flickers quite a bit.
  • Some of us have more eye pain from motion blur than eye pain from flicker.
  • Vision sensitivity to various things vary a lot between humans.
  • Some are sensitive to colors. Others are not (color blindness or partially)
  • Some are sensitive to motion. Others are not (motion blindness called "Akinetopsia", but partial cases exist too)
  • Some are sensitive to flicker (PWM, CRT, strobe, or only some kinds of flicker, etc). Others are not.
  • Some can see perfectly clear better than 20/20. Others are not.
Everybody tends to see slightly differently than the next human.
So if flicker is unimportant, 60Hz blur reduction (e.g. BenQ XL2411P) is sometimes a godsend for those 60fps-locked games or gaming consoles.
Sure, some of these are first world problems, but in the age of PWM-free monitors with GSYNC/ULMB, few monitors are properly targeted to the blur-sensitive. And the mantra of "use VSYNC OFF" does degrade strobe quality somewhat (kills the TestUFO-smooth effect) since framerate-locked motion has less eye-pain when you use strobed modes.
VSYNC OFF is great for low lag. But when using ULMB with refresh-rate unsynchronized motion....uhhhh, excuse me: Fluctuating low-framerate with strobe backlights can create eye pain during strobed operation for some people due to the serrating effect of random multi-image effect, it's like a serrated knife for certain human eyes:
Some people can't stand that, it creates major eye pain (moreso from this artifact THAN from the flicker!) Sometimes flicker is the problem. But we have readers here who get eye-pain from PWM but no pain from ULMB VSYNC ON. So, to fix the problem, you need to lower strobe rate to the same ballpark of the framerate....or preferably perfect match.
Not everybody is bothered by it. But some of us are; the eyestrain disappears for some of us with perfect framerate-matched ULMB.
  • Some of us can tolerate global flash (varying average photons like ULMB)
    Pretty fine with ULMB
  • Some of us can only tolerate rolling scan flicker (constant average brightness; some dot is always illuminated)
    Only motion blur reduction we're comfortable with is CRT
  • Some of us are flicker sensitive of any kind (all pixels must stay continually illuminated)
    These people flickerfree LCDs, PWM-free, with ULMB turned off
  • Some of us are sensitive to the artifacts of flicker (can't stand motion artifacts like double-images)
    People who get eye pain from PWM-dimming but no eye-pain from strobing VSYNC ON ULMB
  • Varying combinations of above sensitivities.
    e.g. eye pain from PWM-dimming and eye pain from ULMB until ULMB reaches 144Hz.
    e.g. eye pain from stutters AND blur. Requiring perfect stutterless framerate-locked VSYNC ON ULMB
    e.g. eye pain from stutters AND blur AND flicker. Requiring ultra-Hz to fix.
    Or other vision-sensitivity combination
Thousands of people. Being the only website in the world, people reach out to me asking questions privately, email, PM, DM, etc. While I tell them to post publicly, sometimes they are desparate and I try to give them the best advice I can sometimes.
Blur Busters has many dozens of cases of EACH category above. Some of it is poorly scientifically studied, but some of the scientific links are also in the lighting industry paper linked from the 1000Hz-Journey article.
If any researcher reading this, I'm willing to fund a peer reviewed study about "motion blur eyestrain" and the varying thresholds of "flicker discomfort" ratio to "motion blur discomfort" that I've experienced hundreds of people with, ever since Blur Busters launched in Year 2012.
Now, keeping this in mind:
--> Respect People's Preferences From Vision Sensitivities <--
No feeding words in other people's mouths, everyone has preferences.
Myth: "Everyone will always hate 60Hz strobe, its useless to everyone" <-- discouraged on Blur Busters
Myth: "You should never bother with ULMB, it's stuttery/jittery" <-- discouraged on Blur Busters
Myth: "VSYNC ON is useless for everything" <-- discouraged on Blur Busters
Myth: "VSYNC OFF is useless for everything" <-- discouraged on Blur Busters
We all have our own preferences!
So, back to low-Hz strobing.
It doesn't help everyone, but some guidelines to make low-Hz strobing better:
1. Sit slightly further away. Modern computer monitors are bigger than CRT screens.
2. Reduce screen brightness or play games with dark backgrounds. LCDs are brighter than CRT.
3. Adjust ambient lighting.
4. Take breaks.
Then it's the lesser poison of "pick-poison" vision problems sometimes. Sure, some of us have to bump to 85Hz ULMB instead of the 60Hz ULMB Hack. Or we're perfectly fine with 60Hz strobing. It's annoying when NVIDIA disallows 60Hz ULMB when some manufacturers enable it. Some manufacturers just simply display a warning message "WARNING: Flicker. Discontinue using if you have headaches [...] yadda yadda" and that's good enough. Some of us need 60Hz strobing.
So, now, there's side effects of low-Hz strobing.
1. Stationary Gaze Issue While Motion Scroll Past: Stroboscopic artifacts
While motion blur is fixed, the stroboscopic effects aren't fixed. The lower the Hz, the more gapped motion is (e.g. steppy or dotty motion in games with high contrast stuff), regardless of whether you do strobing or not.
2. Duplicate images during eye tracking if framerate not matched with refresh rate
That's why strobing often does not look good if frame rate diverges from strobe rate. This is the side effect caused by framerate (not strobe crosstalk caused by pixel response limitations). Same old fashioned CRT/plasma 30fps at 60Hz issue, the old double-image rule occurs when running framerate that is half strobe rate (e.g. 60fps at 120Hz ULMB).
But, if stroboscopic artifacts are no problem, and you're not flicker sensitive....Then...Well, 60Hz strobing is a godsend.
Certainly the strobe lag is a problem for competitive sports but some of us love to play scrolly RTS games that looks amazing with ULMB. With perfect-clear Nintendo-smooth Sega-arcade-smooth TestUFO-smooth ULMB in those scrolly games like RTS or Sonic Hedgehog platformers or if we're an "eye-tracker instead of a crosshairs-starer" in certain turny/scrolly/panny games that have no fixed points of references like a crosshairs. For the non-flicker-sensitive person, 60Hz ULMB hack (or ULMB+GSYNC hack with the RTSS 60fps cap) can be a godsend for emulator use, and look better than software-based black frame insertion.
Low Hz Strobing Can Be Useful Tool
TL;DR Using low-Hz strobing can be a shortcut to motion nirvana than ultra-Hz, if you don't mind flicker or stroboscopic artifacts. You simply lower the strobe refresh rate to just above your flicker tolerance threshold. Then it's much easier to get "framerate = refreshrate = stroberate" with your GPU.
Unfortunately, the only way to solve flicker+stroboscopic artifacts simultaneously with fixing motion blur, will be the ultra-Hz technique of motion blur elimination, instead of the strobe-based technique of motion blur reduction..
However, Refresh Rate Race Must Go On, As One-Size Fixes All
--> 1000fps@1000Hz = No blur, no flicker, no stroboscopics, no stutter, no tearing, no motion artifacts, all gone simultaneously
--> 1000fps@1000Hz = merges all the advantges of VSYNC ON / VSYNC OFF / ULMB / VRR / GSYNC / FreeSync simultaneously into one
--> Even as games catch up, as well as Frame Rate Amplification Techonologies / Framepacing Technologies needing to catch up.
--> New readers: Want to read more about the refresh rate race?
Then read this amazing piece: Blur Busters Law And The Amazing Journey To Future 1000Hz Displays
Notty_PT
Post by Notty_PT » 05 Feb 2019, 00:53
Any ETA about this monitor? And does anyone know if it will be released on Europe aswell? I can´t wait to have this beauty.
- My favourite size for competitive gaming - 21,5 inches
- Oled for 0,1ms response time and amazing motion clarity on fast mouse flicks
- 144hz + 0,1ms - no comments!
I hope it doesn´t cost more than 500€, if it will be available on Europe. This is the only monitor that I will consider to replace my XG2402 as the king of gaming monitors!
I can see a lot of pros going to buy this. The size and the fact it has almost no motion blur will make it the perfect competitive weapon!
