New round of tests coming? Nvidia cards with freesync?
Re: New round of tests coming? Nvidia cards with freesync?
Post by jorimt » 10 Jan 2019, 00:26
Chief Blur Buster wrote:I have a PG258 and an XG258.
The GSYNC and FreeSync versions of the ASUS monitors!
I was going to write about this for Holidays, but now they will become used for this test.
I will do some quick benchmarking.
They will not be as extensive as GSYNC 101 but they will allow me to compare 240Hz VRR.
It will certainly be interesting to see the results :)
phatty wrote:However the cost of the Gsync version is anywhere of 80 to 100 dollars more depending on comparing list vs sale pricing.
If we are at a point in time where it "doesn't matter" if it's gsync or free sync, why spend the extra money on the gsync module
Quality of life improvements, basically.
With every single G-SYNC certified desktop monitor containing a hardware module, you're guaranteed optimal overdrive performance (both in VRR and non-VRR operation), no frame skipping (which can also contribute to a more stable factory overclock mode), ULMB (in most models), as well as optimal performance in the most tricky area for VRR (or for any syncing method, for that matter); low, and/or highly variable framerates within the working refresh rate, effectively all the way down to 0.
Nigh unavoidable frametime variances and spikes caused by the system introduce the most potential issues with VRR, and much of that (especially with frametime spikes) occurs in the lower refresh range.
If everyone could play every game with the framerate at their VRR monitor's max refresh rate at all times with a simple -2 or -3 FPS limit, then no, the difference between hardware-based G-SYNC and software-based FreeSync (1 & 2) wouldn't matter much at all.
But that is obviously rarely the case, and G-SYNC has a hard enough time in these instances doing it with hardware, so I doubt even FreeSync 2 (as far as I'm aware) does it quite as well, and since most people buying these VRR monitors don't have systems that can run all their games (or even most) at framerates at or above their max refresh rate at all times (particularly with games maxed out), how a VRR monitor deals with highly variable (sometimes sporadic) framerate performance, along with how large its working range is (especially at the lower end), can become pretty vital.
So, while, yes, adaptive sync is adaptive sync, G-SYNC is undeniably adaptive sync "plus"; the "premium" may not be worth it to everyone (which is both perfectly acceptable and understandable), but it does have its worth nonetheless.
Also, just because something (if even only slightly) superior (or otherwise) is more expensive than something (if even only slightly) inferior (or otherwise), doesn't mean it shouldn't exist solely because it's more expensive.
That said, history has shown that the superior option doesn't necessarily always win out, so we'll see. Regardless, no matter how it all pans out, I think it's safe to say more accessible, cost effective VRR is a ultimately great thing for every gamer; choice is good ;)
EDIT: Just saw this:
https://www.youtube.com/watch?time_cont ... yCiBbQh2fA
Which brings up another point here; with Nvidia making this move, they're going to be basically exposing subpar monitors (frame skipping, vblank/timing issue, no variable/adaptive overdrive, poor VRR range, etc), which will probably indirectly force the QC to improve for the worst of the FreeSync/non-G-SYNC VRR displays.
celpas
Post by celpas » 10 Jan 2019, 03:55
Now that nvidia cards support FreeSync, does this mean manufacturers will stop producing newer products with midrange gsync panels like Acer xb271hu/Dell S2417DG/S2716DG or will similar new monitors continue to be produced? This would be a downer as gsync modules had some advantages over FreeSync.
pox02
Post by pox02 » 10 Jan 2019, 04:19
Aw2518hf + vt tweak + super fast + gsync the feeling gonna be extreme im ready
Post by Chief Blur Buster » 15 Jan 2019, 14:32
FreeSync driver arrived!
It will take a few days to test -- I have a huge slate of other work including this one.
xenphor
Post by xenphor » 16 Jan 2019, 16:21
I'm most worried that support is limited to Windows 10 with a specific driver version and thus probably more susceptible to any sort of driver/Microsoft shenanigans. I mean we already see how Windowed gsync has been broken for awhile now (I don't have a gsync monitor, just what I've read) so who knows what kind of things will break with this sort of "unofficial" hybrid support of freesync. I'm guessing it won't be very high on the priority list of things to fix for nvidia when even their own gsync implementation does not work correctly in Windowed mode (correct me if I'm wrong; still waiting to buy a VRR monitor until things stabilize). Of course I would love to buy a cheap freesync monitor and have it work fine.
I suppose at this point it's better to just wait for HDMI VRR since Nvidia will probably support that if they are doing this already? That way you will have the most options for VRR.
