About Asus VG258QR input lag
MatrixQW
Re: About Asus VG258QR input lag
Post by MatrixQW » 22 Feb 2019, 12:47
Battlenonsense tested vg258q, so even though it uses the same panel, it's possible vg258qr does not have this issue. Prad does indeed indicate low input lag. Would have to ask them if they tested it with nvidia.
Would be nice to know how much input lag it has with ELMB.
Would be nice to know how much input lag it has using 144hz instead of 165hz. Will it use same overdrive with different hz?
pox02
Post by pox02 » 22 Feb 2019, 13:00
MatrixQW wrote:Battlenonsense tested vg258q, so even though it uses the same panel, it's possible vg258qr does not have this issue. Prad does indeed indicate low input lag. Would have to ask them if they tested it with nvidia.
vg258q(14.1ms) vg258qr(2.3ms) its hard to tell how much input lag can be added with elmb on
Notty_PT
Post by Notty_PT » 22 Feb 2019, 13:27
edit: this is not same as "Q" model
Erdo4
Post by Erdo4 » 22 Feb 2019, 14:00
I've asked to prad.de if they have performed that test with nvidia gpu. In the meanwhile I already ordered VG258QR. If I don't happy with the results I could always sent it back for full refund anyways.. I only hope they fixed that with newer QR model.
pox02
Post by pox02 » 22 Feb 2019, 15:52
Erdo4 wrote:I've asked to prad.de if they have performed that test with nvidia gpu. In the meanwhile I already ordered VG258QR. If I don't happy with the results I could always sent it back for full refund anyways.. I only hope they fixed that with newer QR model.
you will be happy with it :D test it with gsync let me know if its work 8-)
edit found out its not working on gsync and above trace free 40 its cause ghosting/overshoot/trailing :x
boykale
Post by boykale » 22 Feb 2019, 16:27
Please let us know if you get reply from prad.de
Erdo4
Post by Erdo4 » 22 Feb 2019, 16:58
If I recall correctly, one of the owners of 258QR wrote on reddit that he has gsync option in control panel and was able to activate it.
Do you mean freesync/gsync disabled with trace free 40 causing issues? Wasn't it default 60 and shouldn't be an issue as long as you not pushing it up to 100?
@boykale
Sure :)
pox02
Post by pox02 » 22 Feb 2019, 18:02
@boykale
Sure :)
i ask twitch streamer that have this monitor https://www.twitch.tv/soulmercs he told me
gsync not work on this monitor and default could be 60 but its cause ghosting so he reduce it to 40
Q83Ia7ta
Post by Q83Ia7ta » 22 Feb 2019, 21:35
Erdo4 wrote:... and saw this new VG258QR 0.5ms monitor. I was searcing info about it and found displayspecifications.com
It says input lag is 14ms
I was also looking for XG2402 which has 3ms input lag.
How does it has 14ms input lag at 0.5ms VG258QR monitor?
response time and input lag are different things. use search.
Erdo4
Post by Erdo4 » 23 Feb 2019, 05:47
@boykale
I have received reply from prad.de
The test was done with nvidia gpu. (thankfully) so looks like they have fixed it with new model.
