Re: Can OLED, ULED XD, MicroLED,... be blur free under 60Hz?
Posted: 30 Oct 2025, 19:48
For same display tech, CRT vs CRT, higher Hz is definitely less eyestrain.i_apocalypseon wrote: ↑30 Oct 2025, 07:20On a slightly different topic, is 60 hz crt flicker more of an eyestrain, than say 120hz on a pc crt monitor?
But if you compare across display tech, a low-Hz CRT flicker may be less eyestrain than a high-Hz global-squarewave strobe. (e.g. for some people, 85 Hz CRT might be less eyestrain than 120Hz global-strobe backlight).
It's all about the nuances. A rolling flicker means the display is emitting light at least somewhere on the display surface.
