G-Sync+vsync question
bawkachoy
Re: G-Sync+vsync question
Post by bawkachoy » 17 May 2022, 20:56
jorimt wrote:
22 Feb 2022, 20:04
spysmily1 wrote:
04 Nov 2021, 00:07
I have the same problem as you originally posted. I have Gsync and Vsync on in the control panel. I am capped at 225fps but will max out at 240fps with Vsync off. I initially had Low Latency Mode OFF and turned it ON as the one guy suggested. It did not work for me.
Does this setup still work for you? I'm just trying to find solutions and you seem to be the only person posting this. I believe you had posted on Reddit and in Nvidia's comments section too.
Goodlie wrote:
16 Feb 2022, 23:19
I currently am dealing with the same problem how do i fix it 🙏🙏🙏
This is expected behavior; LLM Ultra's auto FPS limiter only activates with G-SYNC + NVCP V-SYNC enabled.
You'll need to set a manual FPS limit if you want to use G-SYNC on + V-SYNC off (or G-SYNC + NVCP V-SYNC + LLM "On") instead.
I don't know if this discussion has been closed or not, However I am currently having issues with G-Sync (FreeSync) On + NVCP V-Sync On + LLM On using my Lenovo Y25-25 where my FPS caps at 225 for every game. I am using rivatuner to cap my fps at 237, but it isn't needed because my fps is being stuck at 225. I tried turning off NVCP Vsync + LLM Off as well as turn everything off (GSync,VSync,LLM) to check if rivatuner is working which it does. Any ideas or help would be appreciated.
Post by jorimt » 18 May 2022, 08:20
bawkachoy wrote:
17 May 2022, 20:56
- G-SYNC + NVCP V-SYNC + LLM "Ultra" will enable the automatic ~225 FPS cap at 240Hz.
- G-SYNC + NVCP V-SYNC + Reflex will enable the automatic ~225 FPS cap at 240Hz.
If the cap is still applying in situations for you that don't apply to the above scenarios, more details would be needed.
bawkachoy
Post by bawkachoy » 18 May 2022, 17:16
jorimt wrote:
18 May 2022, 08:20
bawkachoy wrote:
17 May 2022, 20:56
Ah okay I have no checked out the G-Sync + NVCP V-Sync + Reflex and think that may be the issue. Will be disabling Reflex to test if that is the issue. Thanks for your help.
Post by jorimt » 18 May 2022, 20:38
bawkachoy wrote:
18 May 2022, 17:16
No worries.
