Best monitor for competitive edge in GAMING? (small list inside)
MoniThor
Re: Best monitor for competitive edge in GAMING? (small list inside)
Post by MoniThor » 28 Jan 2020, 09:03
BTRY B 529th FA BN wrote:
25 Jan 2020, 22:20
What's wrong with the HP Omenf? Seems to have the lowest input lag of 2.6ms
https://www.rtings.com/monitor/tests/inputs/input-lag
And a fast 5.3ms motion blur
https://www.rtings.com/monitor/tests/mo ... ponse-time
The lack of eye, -vision protection. For me, it is very important. On the official HP website I could not find data on that, correct me if Im wrong. Please.
dutchie84 wrote:
26 Jan 2020, 09:41
Zowie xl2546 has great strobe crosstalk fine tuning , all 240hz monitors suffer crosstalk but if you can finetune it that is to me very important
Thanks for the great info!
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 28 Jan 2020, 11:56
MoniThor
Post by MoniThor » 28 Jan 2020, 13:29
28 Jan 2020, 11:56
@MoniThor I've never heard of that before until now. What is this '-vision protection' property, within a monitor, you need?
Thanks
For example, check this out: https://www.asus.com/Microsite/display/ ... echnology/
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 28 Jan 2020, 15:00
ogchampion
Post by ogchampion » 29 Jan 2020, 07:23
25 Jan 2020, 22:20
Nothing wrong with the Omen X25f. Best 240hz monitor I've had, and I've had a lot.
camaoyba
Post by camaoyba » 29 Jan 2020, 09:51
ogchampion wrote:
29 Jan 2020, 07:23
25 Jan 2020, 22:20
Could you share your settings?
Max_hz
Post by Max_hz » 29 Jan 2020, 11:30
ogchampion wrote:
29 Jan 2020, 07:23
25 Jan 2020, 22:20
I bought the X 25f two times and both suffered from pixel inversion (vertical lines) in game beside that
it's a nice and fast monitor.
Post by Chief Blur Buster » 29 Jan 2020, 12:51
Max_hz wrote:
29 Jan 2020, 11:30
Inversion artifact.
Inversion is a 100% normal invisible algorithm built into all LCDs.
It's supposed to be invisible most of the time but sometimes it isn't.
What you are seeing is an inversion artifact.
Do not confuse "inversion" (LCD-balancing method) with "inversion artifact" (occasionally visible side effect)
Max_hz
Post by Max_hz » 29 Jan 2020, 14:28
Chief Blur Buster wrote:
29 Jan 2020, 12:51
Max_hz wrote:
29 Jan 2020, 11:30
Inversion artifact.
Thanks for correcting me Chief! I forgot the word "artifact" indeed (me noob) ;).
Back to the X 25f for me it wasn't occasionally.
Genadio
Post by Genadio » 29 Jan 2020, 15:06
The announced Eve Spectrum is also quite an interesting option.
By the way, Chief Blur Buster, did you really write several posts on their forum? There is an assumption that all these pre-orders for the monitor may be a scam.
