Re: Vg259qm Vs XF252QM?
Posted: 01 Apr 2020, 10:19
Wait, what?
Why the asus looks so clear??? I already ordered the VG259QM version (24 inch) because 1080p is better on 24 than on 27 inch but I knew that only downside of that monitor will be motion blur reduction, I saw this tests over here:
https://www.tftcentral.co.uk/reviews/as ... g279qm.htm
And they uploaded this picture, and it is with the ELMB (which hurts the eyes, so I would not use it anyway)
And now after I saw that on your video, that looks actually much better than I thought, so actually this Asus is better than this Acer (TN!) + asus has top1 response time of IPS Panel, it is actually only 1ms slower than my TN + it has very low input lag.
I dont know why it is also so cheap... I only hope the version of VG259QM will has same panel, and will be same fast, because I found some difference like VG259QM has 4ms response time, instead of 1ms compare to VG279QM.
I really hope they didnt do amazing 27 inch monitor, and they knew that ppl will buy VG259QM (which hopefuly they will not make worse) anyway because 24-25 inch works better with 1080p.
