Not sure which ones you can get in germany, but make sure it is VESA certifiedtuvok_ wrote: ↑30 Apr 2020, 12:53wow i got the same issue with the ViewSonic XG270 Elite
look:
when i change to PC-RESOLUTION screen is not smooth and clear.
I Just have 1920x1080p NOT Native with 240, 144 and 100Hz.
Any Recommendation for a high quality DP Cable?
I doubt that will fix the problem though. I'm using a good cable as well and tried multiple
I think it might just be a bug in nvidia's driver. I watched a couple of AW2518hf reviews and TV resolutions also appear in nvidia control panel
If you really want to get rid of it, you can delete the TV resolutions with CRU.
