I'M SO CLOSE TO FINISHING MY INPUT LAG!
Brainlet
Re: I'M SO CLOSE TO FINISHING MY INPUT LAG!
Post by Brainlet » 01 Jul 2020, 19:18
Because W7 is so much better than 10 the scheduler optimizations on 10 wont compensate for it. As for security, dual boot a W10 install on another partition/drive.
Starting point for beginners: PC Optimization Hub
deama
Post by deama » 02 Jul 2020, 05:09
RamenRider wrote: ↑
01 Jul 2020, 19:03
deama wrote: ↑
01 Jul 2020, 05:30
I don't see why you can't just install windows 7, disable dwm, and go on with your life, trying to tame windows 10 is futile.
After a few years, or several, try using linux, it keeps getting better and better for gaming every passing year.
Brainlet wrote: ↑
01 Jul 2020, 11:03
You dont need to update Windows 7. You can just use it in its pure, high performance , vulnerable state without security mitigations if youre only going to play games on it and use a patched W10 for everything else.
I wish you guys would read my posts before replying. Why would I be using Win 7 on a 3900x 5700xt build without any of the security or scheduler optimizations ?
Unless you're gonna be using your gaming computer for sensitive work, security shouldn't concern you, especially if you don't visit shady websites.
RamenRider
Post by RamenRider » 02 Jul 2020, 08:56
I've gotten this far. It's too late for me now. I've found almost every possible tweak there is. This final tweaks goes down to the root core of the problem. Everything else is just Icing on the cake.
senny22
Post by senny22 » 02 Jul 2020, 09:47
RamenRider wrote: ↑
02 Jul 2020, 08:56
What tweaks would you actually recommend doing that actually have a advantage in terms of input lag.
Mr1991
Post by Mr1991 » 02 Jul 2020, 15:16
RamenRider wrote: ↑
02 Jul 2020, 08:56
Bare install of w7 is still better than tweaked 10
senny22
Post by senny22 » 02 Jul 2020, 16:10
Mr1991 wrote: ↑
02 Jul 2020, 15:16
RamenRider wrote: ↑
02 Jul 2020, 08:56
Even though you have a ryzen 3000 series that isn't supported on windows 7 and can't benefit from it's optimizations?
RamenRider
Post by RamenRider » 02 Jul 2020, 16:35
I've tried Win 7 on Ryzen 1600 before. It's not really worth it, especially for multi monitor setup. The input lag still returned because it got shitty updates from Win 10. So much work to get it to install too.
senny22
Post by senny22 » 02 Jul 2020, 17:09
RamenRider wrote: ↑
02 Jul 2020, 16:35
Guess I'll stick to W10 then but what are some tweaks that have actually helped for you? The only tweak I've found to help is setting the HPET timer.
RamenRider
Post by RamenRider » 02 Jul 2020, 19:48
senny22 wrote: ↑
02 Jul 2020, 17:09
Man what the heck is up with this damn forum; does no one read anymore? Why do I always need to repeat myself. Everything I needed to say is literally on the first post of this thread. Look at the first link from my AMD guide.
1000WATT
Post by 1000WATT » 02 Jul 2020, 20:27
RamenRider wrote: ↑
02 Jul 2020, 19:48
What you call a guide. More like a memoir.
In short.
You have come a long hard way. After reading the huge guide, you inspiredly tried everything that was offered. And talked about their feelings.
Ultimately, the conclusion is that ryzen is not optimized on older versions of windows and you don’t get the expected performance, and on newer versions of windows, the incoming lag + broken efs.
Am I missing something?
