Page 2 of 4
Re: Is there a way to make DX12 games run in "true" fullscreen mode?
Posted: 21 Feb 2021, 18:25
by empleat
BTRY B 529th FA BN wrote: ↑
21 Feb 2021, 18:12
Just found this. Reg key to enable or disable MPO.
LMAO only thing I found in French: https://www.touslesdrivers.com/index.ph ... _code=7923
Translated mpo_restore.reg will indeed delete value from registry and restore default configuration. So it should be enabled by default! I tried windowed mode - borderless in BF1 DX12 and it was V-SYNC level of lag :lol: 1000 times worse then FSO and DWM! I am on 461.40.
Posted: 21 Feb 2021, 18:39
by BTRY B 529th FA BN
Posted: 21 Feb 2021, 18:43
by empleat
21 Feb 2021, 18:39
I don't see it either, but input delay does feel like it has decreased with these 461.40 drivers. Of course 'feels' is subjective though.
Yeah depends, I was on these awhile. And depends on game, Windows could activate it in a game x and not in my game... Hope someone will find how to force it. Windows 10 feels like shit on gaming compared to Windows 7!
EDIT: :lol: it works, forget that G-SYNC is enabled only in fullscreen mode by default! Latency is now better than on DX11 FSO disabled! Amazing!
Hmm, not sure it is working, as DWM usage spikes to 15% cpu. I am on i5 9600KF, that's a lot. But it feels better still, than DX 12 fullscreen for sure. I have frame time issues currently so it is hard to tell...
EDIT2: Also I would be interested, if this works in VR. I don't know what mode VR uses, so far didn't notice option in game to change it.
Posted: 25 Feb 2021, 05:40
by slaver01
empleat wrote: ↑
21 Feb 2021, 18:43
21 Feb 2021, 18:39
I currently use the 457.30 driver. In terms of latency (461.40) are there any improvements on DX11 FSO?
Posted: 25 Feb 2021, 16:26
by empleat
slaver01 wrote: ↑
25 Feb 2021, 05:40
empleat wrote: ↑
21 Feb 2021, 18:43
21 Feb 2021, 18:39
How would I know :D It is not like I am testing every driver against every other :D
To disable FSO until DX12:
Save as .reg file, then double click, first you can export given key in registry to easily revert changes.
Code: Select all
[HKEY_CURRENT_USER\System\GameConfigStore]
"GameDVR_DXGIHonorFSEWindowsCompatible"=dword:00000001
"GameDVR_FSEBehavior"=dword:00000002
"GameDVR_FSEBehaviorMode"=dword:00000002
"GameDVR_HonorUserFSEBehaviorMode"=dword:00000001
To verify this is working, try to change volume, if you see pop out window, FSO is still on!!!
Tho MPO works nice on fullscreen borderless, tried that in another game using Vulkan and input lag is amazing! For that you need 461.09 at least!
Posted: 28 Feb 2021, 11:05
by TTT
I tried to get to the bottom of this for a long time and have given up. :lol:
I remember reading elsewhere that some of the newer games (Or potentially all DX12 if non work) don't disable it because the game literally doesn't have an exclusive fullscreen mode, the fullscreen option in game only works with FSO.
Destiny 2 is DX11 and disabling it does work, but I got a bug quite often where if I minimised, the screen just got stuck in a black box that I couldn't get back into. So I have to force close the game every time. I ended up leaving FSO on because of it.
Posted: 28 Feb 2021, 15:36
by empleat
TTT wrote: ↑
28 Feb 2021, 11:05
Disabling it doesn't even work for DX12/Vulkan, so you are safe!
Black screen? Hmm strange, I did not have problems with it so far. Can be game specific. You still need to tick each app in compability tab, so putting this to regedit, doesn't force it on apps.
Posted: 01 Jun 2021, 13:51
by drgokus4star
Yes so now, in most modern DX12 games, you want to leave "Disable full-screen optimizations" un ticked! as this by passes the WDM vsync. more people need to learn this as disabling full screen optimizations isn't the way to go anymore.
Posted: 04 Jun 2021, 03:33
by slaver01
drgokus4star wrote: ↑
01 Jun 2021, 13:51
doesn't work. adjusting sound using media keys on keyboard, i see pop out menu, FSO is on.
Win 10 20h2 - nvidia driver 461.92
Posted: 04 Jun 2021, 05:07
by RealNC
slaver01 wrote: ↑
04 Jun 2021, 03:33
What's the issue you're having, exactly? The new fullscreen mode is just as fast as the legacy one.
