What is VRR strobing?Chief Blur Buster wrote: ↑29 Mar 2021, 19:25Great experience feedback!
That said, I want to offer two additional options for reducing strobe lag even further:RTSS Scanline Sync + strobing tends to be marriage made in heaven.
No capping needed, since even 0.1 or 0.01-fps-below can generate latency sawtoothing from fps-vs-Hz slewing beat frequency effect:
There can still be a weird latency sawtooth even for 119.99fps cap at 120.00Hz strobe (beat-frequencying every 100 seconds).
The great thing is that this sawtooth-changing latency is fixed by RTSS Scanline Sync which allows perfect framerate=Hz without VSYNC ON latency. It's achieved by synchronizing tearlines just right above the top edge of the screen, creating a tearingless VSYNC OFF mode that looks identical to VSYNC ON. The software is a bit difficult to use/calibrate though, and requires a bit of GPU headroom to work reliably.
However, VRR is a good competitive advantage in certain games. ELMB-SYNC is also one of the lowest-lag "framerate=Hz" strobing techniques (and single strobe as long as you keep framerates really high, within 40fps window of max), to avoid the artifacts of low frame rates. Large Vertical Totals can accelerate refresh cycle delivery from PC to monitor, e.g. transmitting a 120Hz refresh cycle in 1/240sec over the video cable. It depends on whether you're using a slightly lower refresh rate strobing than max.
So that boils down to two world's lowest lag perfect framerate=Hz strobing:
- Capped VRR strobing; or
- RTSS Scanline Sync + Strobing + optional Large Vertical Total (for Quick Frame Transport)
This can minimize strobe lag to the point where your human reaction time advantage usually exceeds any now-smaller lag penalties (from strobing / from capping).
no pros use DyAc+ [at least in CS:GO, even though #1 pro in Rainbow Six uses DyAc]
drmcninja
Re: no pros use DyAc+ [at least in CS:GO, even though #1 pro in Rainbow Six uses DyAc]
Variable refresh rate strobing such as ASUS' ELMB-SYNC.
- axaro1
Some Pro players use Dyac in Valorant, idk about CSGO but the two games are very similar.
https://www.twitch.tv/bardozzz/clip/Ugl ... &sort=time
This guy is a pro player for Reply Totem and he has multiple #1 scores in Kovaak, he's one of the best mechanical aimers in EU and he constantly plays with pro players at the highest level (he's always playing with/against players from teams such as FPX, Gambit, Ascend, G2,...)
I watched his stream when he was trying the XL2546K.
He said that Dyac didn't really make a difference in Kovaak since he wasn't able to beat his highest scores but once he switched to Valorant he started praising it.
The main benefit of Dyac in Valorant:
https://www.twitch.tv/videos/969103436?t=1h30m0s
After he tries Dyac OFF right after playing with Dyac ON:
https://www.twitch.tv/videos/969103436?t=1h31m55s
Some more stuff he said:
https://www.twitch.tv/videos/969103436?t=1h36m54s
↑ If you try to run Blurbusters' scanskew test with Dyac ON you'll immediately understand what he's talking about, it perfectly simulates looking at a target while moving your camera horizontally, the Ufo has absolutely no ghosting with Dyac Premium + AMA High/Premium, it's as clear as the reference image.
https://www.testufo.com/scanskew#speed= ... 4¢er=1
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
*= currently owned
OpticBlast
For Warzone where you average about 170 fps which low motion blur monitors are best in your opinion?
ysenojftw
Chief Blur Buster wrote: ↑01 Apr 2021, 21:16Variable refresh rate strobing such as ASUS' ELMB-SYNC.
I have this monitor, how do you do asus elmb sync? Turn gsync on, then low lag on, vertical sync on in nvcp, and then set fps to 275? Where do I turn elmb on in this setup?
