XL2420Z V2 FIRMWARE on Amazon.com! [CONFIRMED]
shedokan
Re: XL2420Z V2 FIRMWARE on Amazon.com! [CONFIRMED]
Anyone can confirm the BenQ XL2411Z on amazon is V2 as well?
really urgent
Yes for USA and Canada.shedokan wrote:Anyone can confirm the BenQ XL2411Z on amazon is V2 as well?![]()
really urgent
BENQ XL2411Z on Amazon is now always Version 2 in USA/Canada
BENQ XL2420Z on Amazon is now always Version 2 in USA/Canada
BENQ XL2720Z on Amazon is now always Version 2 in USA/Canada
(Info accurate as of June 2014 for USA/Canada. Not confirmed for Europe)
shedokan
thanks alot <3
is that mdrejhon? sick forum you set up here!
Yep, that's me!shedokan wrote:thanks alot <3
And thanks for the compliment on these still-relatively-new forums!
Cheers,
Mark Rejhon
alex667
are the any new theorys or updates when this monitor will come with v2 into EU ( germany ) stores?
They are already V2 when buying from BENQ's EU store.
Some scattered reports of V2 from various Amazon EU stores, but should probably be becoming consistent this month or next. If you want to take the risk, go ahead and click the above links in my post above -- just be prepared for conditionally doing the upgrade.
shedokan
hey chief, I downloaded the storbe utility and it says supported monitor found, it means I got a V2? I can't find a way to check if mine is a V1 or V2
Yep! It means you already have V2 firmware.shedokan wrote:hey chief, I downloaded the storbe utility and it says supported monitor found, it means I got a V2? I can't find a way to check if mine is a V1 or V2
csreades
Any information for .co.uk? Or is there a thread for UK suppliers?
monitor_butt
Just got one from Amazon US, came with V2. Shipped from PA.
