bro the cable you bought is not even optic fiber, it's a normal hdmi cable.. the brand is called fibbr, but it's not fiber optic.3xil3 wrote: β06 Sep 2021, 13:14Jusr heads ive found epersally cards exhaust out backlike my 3080FE air causing wierd EMI with monitor cable. once i move cable upwards away from any air from GPU lag gone. Depedning on if works or not you can tell if lag slowly comes back better it is longer take for lag. You can eliminate by gettting fiber displayport or HDMI.
Think cable act as EMI antenna for GPU. Other hardware dont seem to cause this only video card. If possble keep away from any case fans exhauting out air. probably be impossllbe but you will see it works that why say fiber cable as uses light not wires.
i grabbed one these not here yet but it work qustion is will cause issue gsync ive read these fiber cable work fine though
https://www.amazon.com/gp/product/B07TM ... UTF8&psc=1
[Optical-fiber DisplayPort cable for immunity to interference] Video card monitor cable interference.
Sari
