Separate area for niche lag issues including unexpected causes and/or electromagnetic interference (ECC = retransmits = lag). Interference (EMI, EMF) of all kinds (wired, wireless, external, internal, environment, bad component) can cause error-correction latencies like a bad modem connection. Troubleshooting may require university degree. Your lag issue is likely not EMI.
Please read this before entering sub-forum.
Stimpy7314
Post
by Stimpy7314 » 04 Dec 2021, 07:12
Plznoinputlag wrote: ↑04 Dec 2021, 01:54
Stimpy7314 wrote: ↑03 Dec 2021, 15:50
Plznoinputlag wrote: ↑03 Dec 2021, 15:19
Stimpy7314 wrote: ↑03 Dec 2021, 14:44
Must be yeah, Tried playing with the sb spread spectrum setting in bios, however enabling did nothing and disabling made it smoother i guess? But thats weird because SS is to lower emi?
its electricity brother if u dont have hitreg and all desync and prefired issues and its only blurry monitor that looks color degraded its fixable
The only game that isn't smooth is apex. But i heard that their servers are just ass and feel like u playing on a 30hz monitor. Oh and fortnite too. Like when u move your mouse and u look close to your monitor u see it jitters. But watching from a distance it looks smooth, because its less noticable
yeah apex its sucks but u can try voltage stabilizer that will remain consistent power to your electricity. if its not an options you can try to plug your monitor and computer power cables to different outlets like monitor in one outlet and computer power to other outlet like different 2 outlets. this makes a different in monitor quality for me u can try
Will try! However i only have 1 outlet in my room. And the other outlet is 5 meters away, can i use a powerstrip? And do i need to plug it directly into the wall? (In my room) or can i use a powerstrip for that to?
By the way, sometimes my monitor likes to shut itself off, it goes black for 1 second then it comes back. My guess maybe try a different power cable? Maybe the one i use now is low quality/half broken?
Plznoinputlag
Post
by Plznoinputlag » 04 Dec 2021, 09:22
Stimpy7314 wrote: ↑04 Dec 2021, 07:12
yeah u can use powerstrip. which monitor u have and what cable you using?
Stimpy7314
Post
by Stimpy7314 » 04 Dec 2021, 12:24
Plznoinputlag wrote: ↑04 Dec 2021, 09:22
Aoc 24g2u, i use the cable that came with the aoc
Harts
Post
by Harts » 04 Dec 2021, 13:45
Unreazz wrote: ↑03 Dec 2021, 14:38
has to be electric when you say that you feel it also on desktop
how is it fixable? I am trying to fix my hitreg and desync issues since forever and haven't found a fix yet
akylen
Post
by akylen » 04 Dec 2021, 18:34
Good question , good question
Plznoinputlag
Post
by Plznoinputlag » 05 Dec 2021, 01:47
Harts wrote: ↑04 Dec 2021, 13:45
i mean if its only blurry monitor its its fixable. most likely its not getting enough power or he have voltage fluctations or not stable voltage. voltage stabilizer will fix this. Fixing the hitreg and desync its almost impossible i have this issue too and im living with that man 5-6 years strugglig
Harts
Post
by Harts » 05 Dec 2021, 15:28
Plznoinputlag wrote: ↑05 Dec 2021, 01:47
I tested spartas steps to clear the whole system from electricity yesterday and I gotta say that it definitely made a difference while gaming. It lasted just for one day but it definitely made a difference. My question is what can I do in order to save my system from going back to the old status quo. I can't clear my system like that everyday...
Plznoinputlag
Post
by Plznoinputlag » 06 Dec 2021, 02:06
Harts wrote: ↑05 Dec 2021, 15:28
this is the answer we all want to know but we cant figure out. this bad input lag always came back and we dont know what causing it.
Stimpy7314
Post
by Stimpy7314 » 08 Dec 2021, 17:27
Plznoinputlag wrote: ↑06 Dec 2021, 02:06
I'm getting tired of this, i dont wanna play around 3:00 to have a smooth experience. that is to late. We need to figure something out. Anyone who has a tip just say it maybe it will work somehow?
Plznoinputlag
Post
by Plznoinputlag » 09 Dec 2021, 00:47
Stimpy7314 wrote: ↑08 Dec 2021, 17:27
check if you have reversed polarity in your outlets and main panel
