Scaled Resolution Editor (SRE)
ToastyX
Re: Scaled Resolution Editor (SRE)
Post by ToastyX » 04 Feb 2022, 19:33
Chief Blur Buster wrote:
04 Feb 2022, 13:35
Can Scaled Resolution Editor also double as a Quick Frame Transport Editor, with the standard QFT formula that Blur Busters is credited for? (basically a math formula on automatic max-Hz timings to create a low-Hz large-VBI timing of a target Hz, of exactly the same horizontal scan rate and same pixel clock).
SRE doesn't deal with timing parameters at all. That would be more suited for CRU.
Post by Chief Blur Buster » 14 Feb 2022, 03:47
ToastyX wrote:
04 Feb 2022, 19:33
04 Feb 2022, 13:35
Got it.
Essentially I meant a custom user-defined formula instead of "Manual" or "CVT" or "CVT-R" that executes on an existing EDID mode (or a hardcoded mode built into software, ala Strobelight)
(1) Automatically load an existing EDID mode (usually the highest Hz mode, but could be overriden to a user-selected existing mode)
(2) Execute custom formula on this mode to create special different-Hz mode
This would be useful for a more one-click automatic version of
- Quick Frame Transport (e.g. 60Hz with a 1/240sec scanout)
- Custom ULMB Hz (e.g. 60Hz or 155Hz derived from 144Hz ULMB mode)
Basically, as easy as Strobelight, but still has a formula calculation built into it. Probably easiest way to proceed would essentially be a modification of Strobelight catered to a very specific purpose. (Sent you a PM earlier in the week, which you replied to already.)
