Some New Interesting Findings on My Long Battle With Input Lag and Desync Issues
Anonymous768119
Re: Some New Interesting Findings on My Long Battle With Input Lag and Desync Issues
I am not sure about that "infected" mouse and keyboard theory. I haven't noticed the difference even for one minute between many wired gaming mice, including S-Tier wireless Razer.
https://streamable.com/9ik4y2
What do you think about that? I can't really tell if it is abnormal.
Thatweirdinputlag
Maybe they become magnetized or something similar? I'm trying to find a better suited term for "infected" since it's too broad. Demagnetization also happens naturally over time, maybe that explains why it works normal after you unhook it for a week or so and then hook it back again?Mr1991 wrote: ↑21 Apr 2022, 12:15Some people will tell you otherwise, but I’m pretty confident this is true, since I built a secondary pc for my own personal requirements I noticed a few strange things, I built it for native Windows 7 use so it’s pretty old hardware, when I first built it I originally had some generic ram in it, I ordered some low latency ddr3 ram for it and when I first put it in I instantly noticed an improvement in mouse response, on desktop, at first I thought maybe the ram before hand was simply no good and that was the difference, but after a while this improvement in responsiveness seemed to diminish, back to the state of the older ram, I also bought a usb 2.0 pcie card, so I could have my keyboard on a separate usb controller to my mouse, same thing when I first installed it, thought to myself this is all I needed all along, loaded up a game I was playing, was miss clicking so much less, seemed like clicks just seemed to land more correctly, without me putting much thought into it, a bit of time goes by and as with the ram, it went back to its natural state after a day or so
Now this is where it gets strange imo, I took the pcie card out as I was testing an old ps/2 keyboard to potentially take any load off mouse input, everything was all ok, then, some time after, maybe a month or more, I re-plugged the pcie card to try it again… exact same thing, felt good again, if I let my spare components sit there for a while with no use, (I’d estimate maybe a week or so), it seems to fix that “infected” state, which some people like to call it, I’ve also noticed it to a lesser degree with mice, and other components, my issue is prob no way near as bad as yours, by the sound of it, but the “clean/responsive” vs “slightly dulled down” is still there, it’s mostly me being picky.
I just wanted to write this out because some people who claim the whole “infected” parts thing get labelled as whackos, I’m 99% confident it’s true, but some people say it’s permanent and you need to throw away “infected” peripherals/components, which isn’t true.
Mr1991
You can’t really judge it too much by clicking alone, mouse movement is a constant stream of thousands of input, which is why any discrepancies is going to be more noticeable moving the cursor around, (or moving the crosshair around in an fps), usually (imo) bad electricity will come across as if your inputs are smoothed out, or heavily watered down. And in worse cases some people see worsening of their monitor claritya_c_r_e_a_l wrote: ↑21 Apr 2022, 20:25I am not sure about that "infected" mouse and keyboard theory. I haven't noticed the difference even for one minute between many wired gaming mice, including S-Tier wireless Razer.
Eonds
personally my motion clarity is severely reduced. My latency certainly changes but my guess it's some hardware/OS issue not EMI or anything of that nature.Mr1991 wrote: ↑24 Apr 2022, 13:46You can’t really judge it too much by clicking alone, mouse movement is a constant stream of thousands of input, which is why any discrepancies is going to be more noticeable moving the cursor around, (or moving the crosshair around in an fps), usually (imo) bad electricity will come across as if your inputs are smoothed out, or heavily watered down. And in worse cases some people see worsening of their monitor claritya_c_r_e_a_l wrote: ↑21 Apr 2022, 20:25I am not sure about that "infected" mouse and keyboard theory. I haven't noticed the difference even for one minute between many wired gaming mice, including S-Tier wireless Razer.
Moved for you.MontyTheAverage wrote: ↑10 Apr 2022, 00:51I forgot the possible electrical section is separate. I don't know how to move it there. Maybe admin will help.
If this is determined non-electrical (it's commonly wild goose chases / red herring, alas), we can move it back.
P.S. There's no such thing as an "infected" mouse or keyboard. The bigger problem is the cables of the mouse/keyboard is subject to interference -- moving a mouse cable 3 inches closer to a monitor power supply increased lag for 1 user. (Like the LG 5K WiFi problem that led to a LG monitor recall). There's a lot of non-product-recall situations (e.g. 100 true EMI situations out of 10,000 users) where one gadget is emitting so much EMI that it injects into a mouse cable or keyboard cable. Move all USB cables further away from your other electronics / power bricks.
Also, in high-wire-EMI situations, the best wireless gaming mice can have lower latency than wired mouse. This is rare, but this is one possible solution.
Sometimes the latency is port-related, not cable-related. USB hubs can get congested, especially if you buy multiple high-poll-Hz devices and hook to the same pair of USB ports on the motherboard. Another solution is USB roulette, as some USB ports go really noisy. USB Port Roulette To Reduce Latency: Try different USB ports, try a PCIe USB card, etc
Unixko
our experience is different you need to explain thatChief Blur Buster wrote: ↑28 Apr 2022, 19:14Moved for you.MontyTheAverage wrote: ↑10 Apr 2022, 00:51I forgot the possible electrical section is separate. I don't know how to move it there. Maybe admin will help.
when we got into a fixed place and try play there everything is ok
until we plug our mouse from our place where we have a problem, and again when we plug back a mouse from a perfect place everything is ok you can do that again and again
Mr1991
I disagree, like I said in a previous post if I leave certain hardware components around without usage for a week+, it can have a positive effect on my input, minimal, but it’s there.Chief Blur Buster wrote: ↑28 Apr 2022, 19:14Moved for you.MontyTheAverage wrote: ↑10 Apr 2022, 00:51I forgot the possible electrical section is separate. I don't know how to move it there. Maybe admin will help.
That’s not to say that your idea of cables being close is wrong, tho, but that doesn’t mean other variables aren’t influencing effects, there’s multiple, multiple variables.
Unixko wrote: ↑29 Apr 2022, 10:22our experience is different you need to explain that
This might more deserveworthy be in the other forum, obviously. But I don't have time to validate the OP's likelihood of EMI vs non-EMI, and I simply followed their thread-move request, since this ball could go either direction to either goal line. (But I agree, the non-EMI team is much stronger though)Mr1991 wrote: ↑29 Apr 2022, 16:11I disagree, like I said in a previous post if I leave certain hardware components around without usage for a week+, it can have a positive effect on my input, minimal, but it’s there.
But my reply was not targeted at you, but to validate the possible angle. This is often NOT an EMI issue. However, only >99% of the time it's not EMI (whether it be two sigma or five sigma, pick your number, but it's definitely ain't 100%).
Please note that there is an uncountable number of kinds of desync issues (potentially millions of causes) -- software related, hardware related, etc.
What I say is not necessarily applicable to this specific game for this specific situation.
The true fact neither of us are wrong -- this type of problem is one of those "no two snowflakes are identical"
This ain't a "this or that", "us or them", "red or blue" type of polarized issue. It's a vastly complicated problem containing a horrendous number of variables that are interacting with each other. Sometimes it's a dominoe-effect situation. Desync can be triggered in certain software by very unrelated things.
The problem is that forum threads are silos, and topics have to be moved back and fourth.
NJb
Your story sounds awfully similar to mine. Read this: viewtopic.php?f=24&t=9113
You're literally the first one I've seen who realized the problem also comes from the devices that you plug in.
Sadly, no fix yet
Sadly, no fix yet
Thatweirdinputlag
Since you actually haven't found a fix, I'm assuming the input lag came back? even on an entire new setup and apartment? If that's the case then it would be nice of you to update your thread regarding this, since the last thing you mention there is that everything is working perfectly fine.NJb wrote: ↑10 May 2022, 17:48Your story sounds awfully similar to mine. Read this: viewtopic.php?f=24&t=9113
Sadly, no fix yet
