G-SYNC Upgrade Board Giveaway - FIVE boards! [complete]
Dustmuffins
Re: G-SYNC Upgrade Board Giveaway - FIVE boards!
Post by Dustmuffins » 06 Jan 2014, 21:44
nimbulan wrote:Wow $200? I was expecting $150 at most. That is really disappointing.
Ouch. Same here. If I would have known that I would have held off on purchasing my monitor until I could buy it with the gsync module.
Unfortunately I wasn't eligible to enter the giveaway because my video card isn't compatible yet... :x
nimbulan
Post by nimbulan » 06 Jan 2014, 21:47
From the sound of it, buying a new G-sync monitor may actually be more expensive than upgrading a VG248QE, even with the kit costing $200.
aMunster
Post by aMunster » 06 Jan 2014, 21:52
Exactly. What's the point of that? It initially sounded like the DIY option was cheaper, that's why I opted for it.
Solar
Post by Solar » 06 Jan 2014, 22:08
$200 actually isn't that bad considering the FPGA used in G-Sync appears to retail at roughly $1000. As long as we have access to the features it might offer such as being programmable for mods or future updates, it should be well worth the price.
Post by Chief Blur Buster » 06 Jan 2014, 22:11
Solar wrote:$200 actually isn't that bad considering the FPGA used in G-Sync appears to retail at roughly $1000. As long as we have access to the features it might offer such as being programmable for mods or future updates, it should be well worth the price.
Wow -- which FPGA would that be? I guess they haven't come up with dedicated circuit (ASIC) for G-SYNC use just yet, at least for 1920x1080p 120Hz.
AMD's FreeSync isn't running at 1920x1080 120Hz, so presumably, the FPGA is necessary here.
Either way, the motion quality during 40fps-50fps looked like a greater-than-$200 GPU upgrade, e.g. it sort of looked like I upgraded the GPU massively (more than $200 worth!) for recent highly-variable-framerate games such as Crysis 3 and Battlefield 4, the use of G-SYNC really helps since those games are often too slow to benefit well from LightBoost.
Although I prefer 120fps strobed, my eyes clearly preferred smooth 45fps G-SYNC (fps=Hz) over stuttery 80fps non-G-SYNC (fps!=Hz) non G-SYNC. G-SYNC gave Crysis 3 a permanent "framerate matching Hertz" look even when the framerate fluctuated. Only rare stutters (caused by disk loading / background computer activity) occured, all the remaining GPU stutters went away. The animation at http://www.testufo.com/stutter#demo=gsync shows how G-SYNC can pull off seamless, stutterless framerate transitions. (Well you do get the low framerate feel regular stutter at 30fps, but you don't get any erratic stutter during frame rate transition). If I was using a GPU that limited me to 50fps frequently (e.g. even Titan during Crysis 3 at Ultra settings, get brought to knees very often), G-SYNC improves motion quality more than LightBoost does.
cheneric
Post by cheneric » 06 Jan 2014, 22:12
Congrats to the winners! I didn't expect the mod to be $200...Good luck to the rest.
PoWn3d_0704
Post by PoWn3d_0704 » 06 Jan 2014, 22:13
Having used G-Sync before I can tell you how absolutely beautiful the monitor is.
Asus VG248QE with GSync. Blur Busters GSync Contest Winner.
aMunster
Post by aMunster » 06 Jan 2014, 22:22
When it comes to early adoption, I don't mind spending more than I think I should, assuming I can afford it. I'm willing to believe G-Sync is as good as you say, Chief. If it isn't you'll never see me on the forums again :)
Post by Chief Blur Buster » 06 Jan 2014, 22:30
aMunster wrote:When it comes to early adoption, I don't mind spending more than I think I should, assuming I can afford it. I'm willing to believe G-Sync is as good as you say, Chief. If it isn't you'll never see me on the forums again :)
I have read what you posted, and I think you will probably love it (at least for games that work reliably with GSYNC). That said, it's no guarantee. What's good to me, might not be good to you. There are people, for instance, that do not like LightBoost, understandably -- e.g. more sensitive to flicker or color problem. It quite impressive to some people (like me) in certain games that were too slow for LightBoost benefit. There are some who say "ho hum" to G-SYNC, while it is "WOW!" to others.
Just so that everyone is clear;
G-SYNC: Fixes stutters/tearing, but not motion blur. Best for variable framerates and/or low framerates.
LightBoost/ULMB: Fixes motion blur, but not stutters/tearing. Best for consistently high framerates.
You get both in a G-SYNC monitor, but you can't run both simultaneously.
aMunster
Post by aMunster » 06 Jan 2014, 22:38
Right. This is a technical letdown, but Quake runs at a consistent 125 or 250 fps so it isn't a problem. I'm still skeptical that G-Sync adds a bit of input lag, so perhaps I'm better off using only ULMB. Runescape, on the other hand, runs at low framerates even in the best conditions. The amount of stutter in that game drives me up the wall. The use cases in these two games are on the extreme ends of the two modes offered by G-Sync. Again, I hope it exceeds my expectations, because I love digging into this esoteric material.
