broken scaling cause of heavy/floating mouse, desync, heavy car bug, input lag etc
cumitmuito
Re: broken scaling cause of heavy/floating mouse, desync, heavy car bug, input lag etc
Post by cumitmuito » 30 Dec 2025, 22:44
valhalla wrote: ↑
29 Dec 2025, 15:04
hello guys did anybody find any solution ???? i have the same problem for 7 years now already. the fun fact is i have 4 new computers 4 new monitors.... now i am on a rtx 5080... and my displayport cable is straight into the motherboard..... and the rendering of cs2 is smoother :lol:
I have the same feeling when plug DP cable in mobo. CS2 became much more smoother, easier for tracking and micro adjustment.
The only inconvenience is that the iGPU of the CPU I’m using (7800X3D) doesn’t support the resolution I use in-game. Also, from what I’ve seen, competitive tournament setups usually output directly from the dGPU, which is something I find confusing.
jeffeh12133
Post by jeffeh12133 » 05 Jan 2026, 03:20
naporitan wrote: ↑
29 May 2025, 18:51
ablemor wrote: ↑
29 May 2025, 15:53
And if i set correctly, my game will run good, i mean no floaty mouse?
Yes, but it's important that certain conditions are met.
i have a xl2546x+ and i was debating whether to use display or GPU scaling. for over a year since i got this monitor i've used GPU scaling, "Full Screen" in nvidia CP with override scaling mode set by games and programs checked and it's been fine so far. why do you recommend unchecking it? i'm curious.
another thing, if the xl2546x+ includes Image shouldnt i technically be using display scaling? so far GPU scaling has been fine but i was just wondering.
Post by Slender » 05 Jan 2026, 03:33
jeffeh12133 wrote: ↑
05 Jan 2026, 03:20
naporitan wrote: ↑
29 May 2025, 18:51
ablemor wrote: ↑
29 May 2025, 15:53
yes, u can, but before u need delete gpu 1280x960 resolution in sre.exe.
also, u can see preinstalled display scaled resolution by benq zowie in cru.
also, 30 sec video how to make perfect display scaling: https://youtu.be/gdYcXAtVK2w?si=-A4Lhcs7aGTIjt4l
jeffeh12133
Post by jeffeh12133 » 05 Jan 2026, 03:47
Slender wrote: ↑
05 Jan 2026, 03:33
05 Jan 2026, 03:20
naporitan wrote: ↑
29 May 2025, 18:51
ablemor wrote: ↑
29 May 2025, 15:53
so its technically better to use display scaling huh? display > full screen > checkmark or uncheck?
Post by Slender » 05 Jan 2026, 04:08
05 Jan 2026, 03:47
Slender wrote: ↑
05 Jan 2026, 03:33
05 Jan 2026, 03:20
naporitan wrote: ↑
29 May 2025, 18:51
Theoretically, yes. But if you don't remove the HDMI section and GPU scaled resolution, your games will break when you alt-tab. Oddly enough, the 2546s had better display scaling than my current 2566k. The 2546s felt like CRT. But maybe my XL2566k model is blurry, I don't know. Use what feels best to you, but correctly setting up display scaling before you choose.
Hyote
Post by Hyote » 05 Jan 2026, 17:13
Slender wrote: ↑
05 Jan 2026, 04:08
05 Jan 2026, 03:47
Slender wrote: ↑
05 Jan 2026, 03:33
05 Jan 2026, 03:20
Like with everything else I spent a lot of time trying all the options but always stuck with either Exact Reduced or Exact CRT.
Exact CRT feels the best, though it requires you to use a lower refresh rate.
themagic
Post by themagic » 06 Jan 2026, 12:49
Not about Scaling...
But when I can Post again like normal Human again on this Forum and express my Humans feelings and tell about my Logic ? without that my Posts need to be watched and approved ? what is this state ? like pls ?
qvik18
Post by qvik18 » 17 Mar 2026, 10:23
got XG2431,aren't there any fix,please helpp
naporitan
Post by naporitan » 17 Mar 2026, 11:00
qvik18 wrote: ↑
17 Mar 2026, 10:23
This topic is not relevant and all information here is unreliable.
