All the 240hz models I tried had a big problem dealing with lower framerates than 200! It gets blurry for my personal taste, bad overdrive, and the experience is not as good as I want it to be!gabethomas wrote:Notty_PT wrote:Hi there! TO be honest if you already have a freesync 144hz monitor it isn´t worth it to "sidegrade" to another model, even if that model (ViewSonic XG2402) is better (faster on both input lag and pixel response time). Unless you are an enthusiast and want to try it out, no need to in my opinion! You already have a legit model!Hypnotic wrote:Hello Notty_PT man im really impressed you've been through the pains a lot and learn so much i will greatly appreciated if help a bit.
I have Acer XF240H 144hz freesync with:
CPU Fx 8320
GPU RX 580 Nitro +
16gb. ram 1866hz.
and planning to try new monitor my f.p.s. is somehow steady most of the time i use Vertical refresh enhanced sync
and amd freesync a.m.d. optimized but i play on full hd,almost everything on low and medium are ViewSonic XG2402 144hz will be better choice i mostly play Battlefield 4 and Destiny 2 for changeon future i hope World War 3.
Respect
Hi there! I would advise you to still try 240hz if you can, because we are all different and you might like it. Altho, if you want to go 144hz route and you can´t buy ViewSonic you have LG 24GM79-B, for example, wich is a great 144hz TN model!gabethomas wrote:Dear Notty_PT !
I'm only registered for this site, because maybe you can help me. I neverd tried 144hz or 240Hz (had a 14 year old LG FULL HD monitor 60Hz), but I feel as you are totally right with the 240Hz thing.
I wanna buy now a new monitor, but reading after days can not know what is the best options. My first point was 240Hz , but after I read your "Why I'm done with 240hz" now is 144hz.
I want to use the new monitor only for competitive FPS games (primary : fortnite) . My setup : RTX 2060, Ryzen 5 2600x, 3000Mhz G.SKILL RAM.
What do you think which are the best 144hz monitors now ? / * good colors are important us for me / G Sync need or good idea for competitive FPS ?
* Viewsonic not option in my country
Thank you so much ! I do not really like the LG (external) , but I will se.e.
Only three question if it not problem :
If I bought a 220hz monitor and I do not like it, good idea to use it on lower Hz ? Or on lower Hz i will can feel that bad symptoms as you wrote on this "Why I'm done with 240hz" article. Still dont know good idea as a 240Hz monitor, because on (for example) fortnite I never get fix 200fps in low settings ( RTX 2060 GPU )
What do you think about Acers ? This model ? : Acer Predator XB241Hbmipr or XB252Q
Every Asus had that " bad color symptom" as the XG248Q ?
Really sorry fot the lot of questions, but very hard to find a good monitor, especially if you live in a poor country and you can not try it.
With that being said, like Chief said, we are all different and you should always try 240hz for yourself. You might not be as picky as me and have a great time with it.
