Acer 390Hz monitor - XV252QF
Thanks for responding! I’ll probably buy it today! based on what you said it looks like a great experience!
May I ask you what app do you use for better brightness and gamma?
lizardpeter
Does anyone else use overdrive on extreme mode?
i9 9900k | RTX 2080 Ti | 32 GB 4x8GB B-Die 3600 MT/s CL16 | XV252QF 390 Hz 1080p | AW2518H 240 Hz 1080p | PG279Q 144 Hz 1440p
Razer Viper 8K | Artisan Zero Mid XL | Apex Pro TKL | 1 gbps FiOS (Fiber)
Almost everybody, that's the real deal on the QF
daviddave1
on the zowie u can scale on the display.D0kk wrote: ↑05 Apr 2022, 17:34Hey guys, I have a pc with rtx 2070 super + ryzen 3600 + 16 gb 3200mhz and i’m upgrading my 144hz monitor… I mainly play csgo, sometimes valorant and other fps titles and I would like to get as competitive as possible!
I’m considering the xv252qf because of ips + VRB as I’m fairly sensitive to motion blur, however I don’t think my rig can handle 390+ fps for most of the time…
So, does this monitor perform well at 240hz? Or I’ll be better of with a xl2546k(around $120 more expensive for a used one in my region)? I’ve looked at some charts and have watched a few videos but I’m not an expert, so I’m looking for help!
Any feedback is welcome! Thanks guys!
| Now:
| Past: XL2586X 540Hz/PG248QP/271QRX/VG259QM with the Qisda panel/PG27AQN/XL2566K
OD Extreme is best OD
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
*= currently owned
Thanks for the answer!! Ended up getting the xv252qf for price to performance reasons! Also if I end up upgrading my pc, I’ll be able to use it’s full potential!
Is anyone else getting better results tweaking Saturation instead of using DCI?
̶A̶l̶s̶o̶,̶ ̶w̶h̶a̶t̶'̶s̶ ̶t̶h̶e̶ ̶p̶o̶i̶n̶t̶ ̶o̶f̶ ̶t̶w̶e̶a̶k̶i̶n̶g̶ ̶Y̶e̶l̶l̶o̶w̶,̶ ̶M̶a̶g̶e̶n̶t̶a̶ ̶a̶n̶d̶ ̶C̶y̶a̶n̶ ̶s̶a̶t̶u̶r̶a̶t̶i̶o̶n̶ ̶i̶f̶ ̶I̶'̶m̶ ̶a̶l̶r̶e̶a̶d̶y̶ ̶t̶w̶e̶a̶k̶i̶n̶g̶ ̶r̶e̶d̶,̶ ̶g̶r̶e̶e̶n̶ ̶a̶n̶d̶ ̶b̶l̶u̶e̶ ̶s̶a̶t̶u̶r̶a̶t̶i̶o̶n̶?̶ ̶
̶I̶s̶n̶'̶t̶ ̶i̶t̶ ̶r̶e̶d̶u̶n̶d̶a̶n̶t̶?̶ ̶(̶D̶o̶e̶s̶ ̶t̶h̶e̶ ̶s̶a̶t̶u̶r̶a̶t̶i̶o̶n̶ ̶a̶l̶g̶o̶r̶i̶t̶h̶m̶ ̶a̶c̶t̶u̶a̶l̶l̶y̶ ̶d̶o̶n̶'̶t̶ ̶i̶n̶c̶r̶e̶a̶s̶e̶ ̶y̶e̶l̶l̶o̶w̶ ̶s̶a̶t̶u̶r̶a̶t̶i̶o̶n̶ ̶e̶v̶e̶n̶ ̶t̶h̶o̶u̶g̶h̶ ̶I̶'̶m̶ ̶i̶n̶c̶r̶e̶a̶s̶i̶n̶g̶ ̶i̶t̶ ̶f̶o̶r̶ ̶G̶r̶e̶e̶n̶ ̶+̶ ̶R̶e̶d̶?̶)̶
I just set red to 0 and while red became a shade of grey, yellow is still there, so I guess that I need to increase every single value and not just red, green and blue.
*= currently owned
*= currently owned
Manimal 5000
I'll interrupt a minute to say I'm impressed with the monitor. Wish it were bigger, but the blur is not what I feared and down grading from 1440p to 1080 fine. Also impressed by just how much high fps alleviate so many problems, from tearing to blur to lag. You have to put out the fps to let this monitor show them. The strobing looks fine to me (the screen gets brighter not darker) but it's also now acceptable for me to use adaptive-sync, V-sync or just run it raw with little penalty.
Manimal 5000 wrote: ↑12 Apr 2022, 20:39The strobing looks fine to me (the screen gets brighter not darker) but it's also now acceptable for me to use adaptive-sync
I believe that this monitor is, just like the 2546K, using some sort of overvolted backlight.
VRB Normal is 60% off duty cycle (according to RTings graphs) with 468 nits, that could only be possible with an overvolted backlight, especially since it's beating stock brightness with Max Brightness set to ON.
The improvements from using VRB Normal compared to strobing OFF are minor, it's VRB Extreme that squeeze clarity out of strobing.
I'm wondering if VRB Extreme is also making use of this backlight (most likely not, but I could be wrong), I don't know how much off duty cycle is supposed to scale with brightness, maybe with the updated Rtings monitor test bench we might get more data regarding off duty cycle duration of VRB Extreme.
*= currently owned
*= currently owned
Manimal 5000
Just tried that (extreme VBR + extreme overdrive) and yes its pretty crisp. Stationary and moving objects look similar like in the CRT days (hey it only took ~ 20 yrs to get back most of what we lost, and btw, am I wrong in thinking Blur Busters has been a monolithic industry driver in this area?). Did not notice crosstalk in real life with that short test either but didn't really look.
As long as the PC puts out 300-400fps I will probably run it uncapped as it looks and feels plenty "good enough". May change it later. Strobing, unless I'm mistaken needs V-sync on if you want to see the full benefits (sans tearing) and it does feel a bit snappier without V-sync.
