Page 104 of 127
Posted: 30 Apr 2022, 09:58
by lyrill
never had any of these wonk issues. maybe the western low price came with a caveat after all?
Posted: 30 Apr 2022, 16:59
by DPRTMELR
DPRTMELR wrote: ā13 Apr 2022, 19:52
Anyway acer 390hz monitor with tvr off, od normal (i am seeing things on extreme, it's subtle but it's there 100%)
Just double checking this is my lighting/specific unit's quirks, is there any information on what monitor refresh rate the OD setting was was targetted for? Man I should really get one of those input lag testers so I can see if OD extreme is worth on 360hz.
Posted: 07 May 2022, 08:00
by BTRY B 529th FA BN
Posted: 07 May 2022, 08:35
by lyrill
one of the earliest listing of the acer x25 insist on the 390hz being a gimped offer. so why didn't acer oc the x25 then? really weird honestly. and acer also was one of the earliest if not the earliest to tease 4k 240 and I randomly commented about why I think 960hz 1080p is more important and relevant to esport and somehow got to top comment lol..
more rumors of 4k higher hz resurfacing while previously we thought the 2k 360hz was gonna be the main dish next.......
Posted: 08 May 2022, 16:31
by rebuke99
So i just got this monitor, anytime i set it to overclock on and set it to 390hz, the screen keeps cutting out to black non stop
using the supplied dp cable going to a 3070 ti. Do i need to upgrade the cable to the ones im seeing linked in this thread?
Thank you!!
Posted: 08 May 2022, 17:31
by rebuke99
by the way this monitor is amazing outside of not being able to use 390hz without the screen turning off and on
Posted: 08 May 2022, 20:21
Posted: 09 May 2022, 00:08
by shaiuxx
If anyone still has problems with the flickering issue, I found a way to fix it when using a nvidia GPU.
note tho that I have 0 clue what the hell this setting changes and if it can damage the monitor in any way.
Maybe some mod can tell me as the documentation on it just states what it does but not if that's bad or something.
Anyways, here is the scuffed video I made:
https://youtu.be/hqnGeEQJQdc
Maybe gonna make a new one because my setup now is different as i was dumb and used a Capturecard cloning my display with different refresh rates...
Posted: 12 May 2022, 14:34
by Crixlol
Refull wrote: ā06 Apr 2022, 11:35
Playing in 240hz is super fine , the vrb on extreme can be dark for some but I use a app to have better brightness and gamma
What app do you use? Iām finding vrb extreme to be quite a bit too dark.
Posted: 14 May 2022, 03:47
by axaro1
Crixlol wrote: ā12 May 2022, 14:34
Why don't you just use the ingame setting for it?
