Acer 390Hz monitor - XV252QF
zaczac
Post by zaczac » 15 May 2022, 18:44
rebuke99 wrote: ↑
08 May 2022, 16:31
So i just got this monitor, anytime i set it to overclock on and set it to 390hz, the screen keeps cutting out to black non stop
using the supplied dp cable going to a 3070 ti. Do i need to upgrade the cable to the ones im seeing linked in this thread?
Thank you!!
Return it ASAP, its defective. There's two different issues with the monitor, one where it flickers and the other where the screen will constantly go black like its turning off then back on (but quicker). The flickering has a few fixes floating around but nothing for the black screen issue. I had the same issue and after 2 weeks the monitor fully died. I tried different cables, computers etc nothing worked.
lyrill
Post by lyrill » 17 May 2022, 13:29
zaczac wrote: ↑
15 May 2022, 18:44
rebuke99 wrote: ↑
08 May 2022, 16:31
Thank you!!
do you mean it's a qc issue or that ALL copies are defective?
bobatime128
Post by bobatime128 » 19 May 2022, 22:27
Hi Everybody,
I just got this monitor and I’m liking it so far. I’m relatively new to this and I feel like I’m not utilizing the monitor to its fullest potential. I play Apex Legends, I have read that the game engine isn’t the greatest, I can sort of maintain 299+ FPS but it will drop to 180 in certain areas or fights. I know FPS=RefreshRate is ideal but with my fluctuating FPS, should I cap my FPS lower and match the refresh rate? Or higher refresh rate? I saw User:axaro1 plays Apex Legends, so I was hoping maybe axaro1 can chime in and help me out with settings, or anyone that is willing to help. Sorry for the novice question. Thanks everyone
Post by Chief Blur Buster » 20 May 2022, 10:59
The advice varies on settings.
What are your sync technology and strobe settings?
What’s your VRR setting? VSYNC setting? blur reduction setting?
zaczac
Post by zaczac » 20 May 2022, 13:09
lyrill wrote: ↑
17 May 2022, 13:29
zaczac wrote: ↑
15 May 2022, 18:44
rebuke99 wrote: ↑
08 May 2022, 16:31
Thank you!!
QC issue likely. Tons of posts in this thread with no issues.
bobatime128
Post by bobatime128 » 21 May 2022, 01:46
20 May 2022, 10:59
I hope I am answering this correctly. But I have FreeSync and VSync off, and I typically have VRB on Extreme.
Post by Chief Blur Buster » 21 May 2022, 13:33
bobatime128 wrote: ↑
19 May 2022, 22:27
Hi Everybody,
If you are using strobing, then yes, it can be favourable from a panning-clarity perspective to intentionally lower your refresh rate to allow framerate=Hz strobing to look much better. 200fps@200Hz strobing looks much better than 200fps@240-390Hz strobing, because strobing amplifies microstutters / jitters because of lack of motion blur to hide the jitters. Eliminating jitter can improve competitive advantages by keeping better awareness of everything going-on on the screen.
1. Try a slightly lower refresh rates where you're maintaining 90% of the time. Say, 200 or 240Hz.
2. Test VSYNC ON + NULL temporarily (VSYNC ON is not ideal, but this will help you "test drive" the motion quality first)
3. Observe how much better Legends panning looks -- much smoother at framerate=Hz
If you like that motion clarity, then begin optimizing lag. You can optimize lag with QFT (Quick Frame Transport) combined with RTSS Scanline Sync to have the world's lowest lag framerate=Hz. QFT will ensure your 200Hz refresh cycles are transmitted over the cable in 1/390sec per refresh cycle despite a refresh rate of 200Hz. And RTSS Scanline Sync is usually a lower-lag form of framerate=Hz than VSYNC ON.
If you don't like that motionfeel, try temporarily turning off VRB and enabling FreeSync. See if the breathing-framerate looks/feels better. Use a 250fps-300fps cap. It will feel less rough, but will have lower lag than a lower Hz, but will be a lot more motion blurry.
bobatime128
Post by bobatime128 » 21 May 2022, 18:28
21 May 2022, 13:33
19 May 2022, 22:27
Hi Everybody,
Thank you for the very thorough response! I will try that out and see how it works out for me. Really appreciate the help!
lyrill
Post by lyrill » 24 May 2022, 09:26
as this thing only does 8 dither to 10 starting from 240hz downwards and this is for hdr content consumption, most being 10 bit, so most content is 24 or in case of 30 still works with 240
theoretically this is the case but I notice 1 out of 50 frame skip notification on madvr.
not sure if this is relevant to high fps gaming as I dial madvr to highest quality, but then madvr doesn't take as much resource as the most demanding games even for huge bluray disk files on 4000nits or whathaveyou. nor was the source material any high fps to begin with.
Interesting side observation is OW electing to go up to 360 by itself as I remembered my 390 dial. (haven't gamed much forgot to go up from 240. content consumption=deleting the OC just to be safe, even though technically you are not ocing on anything but 390 so it shouldn't really take effect but that's what the UI logic is, it goes through a process whenever you turn on/unlock or turn off/lock "oc" ala "390"
tayzedd
Post by tayzedd » 31 May 2022, 11:16
Manimal 5000 wrote: ↑
12 Apr 2022, 20:39
I'll interrupt a minute to say I'm impressed with the monitor. Wish it were bigger, but the blur is not what I feared and down grading from 1440p to 1080 fine. Also impressed by just how much high fps alleviate so many problems, from tearing to blur to lag. You have to put out the fps to let this monitor show them. The strobing looks fine to me (the screen gets brighter not darker) but it's also now acceptable for me to use adaptive-sync, V-sync or just run it raw with little penalty.
Are you still liking the monitor ? Do you play any tac shooters on it like valorant or CSGO ? I am debating on getting this monitor. I have a Dell S2417DG and don't use it's ULMB because it's not bright enough. I'm debating between this Acer and a Zowie xl2546k. I will probably use the motion blur settings or at least try them out.
axaro1 wrote: ↑
25 Apr 2022, 03:43
BTRY B 529th FA BN wrote: ↑
24 Apr 2022, 14:44
Can you recommend a 1.4 VeSa Certifed DP cable for this monitor for me? One that's overkill in specs and that will support 390Hz? I've been looking on amazon but an not familiar with DP cables. The spare that I am using is a DP cable from my Omen 240Hz.. It eventually started flickering so I went back to the one that came with the monitor, then that started flickering again.. so I'm back to the Omen cable for now. But I need something that is 1000% reliable
Ty
I'm using this one: https://www.amazon.com/Cable-Matters-Ce ... 143&sr=8-6.
Cable length does matter for Displayport Cables, the shorter the better, don't buy 3m+ cables.
Also, if you find one that is marketed as VeSa certified you should also use the official DP VeSa Certified List to double check (https://www.displayport.org/product-cat ... -adaptors/), some products marketed as certified are sometimes not in this list.
With some Amd graphics cards you can control Pre-Emphasis and Voltage Swing to improve Displayport stability with longer cables, it was possible to control these two setting both with my RX580 and 5700XT so I recommend you to give it a try with your 6900XT, it might fix your issues or be an indicator of this issue being 100% cable related.
I'm using a 15 ft DP cable and it seems fine to me. Is the length really that much of an issue? Also quoting you to ask about your experience with this monitor. Do you prefer it to the Zowie xl2546k? What games have you tried both on? Do you play CSGO or Valorant and if so which do you prefer for those games?
