daviddave1
Post by daviddave1 » 05 Jun 2026, 03:35
MSIfanboy wrote: ↑
05 Jun 2026, 02:50
daviddave1 wrote: ↑
04 Jun 2026, 20:09
MSIfanboy wrote: ↑
04 Jun 2026, 17:03
Yes you can make a cru custom resolution and use sre also, I used both, and pulsar still works , I had to turn off scaling in the osd , image, aspect control, scaling off
Tnx!!! so Pulsar works with custom resolutions on 360z? That's good news!! I am a bit confused though cause mawi says he can only make a 240hz custom res just above this message.
yes i am running 24.1 inch mode, pulsar works, scroll back to my former posts a few pages back
tnx aloth! I wil try this soon!!!
| Now: XG27AQNGV
kitabatake_radeka
Post by kitabatake_radeka » 05 Jun 2026, 06:24
A little bit more hardware-related question: I was cleaning the back buttons, and unwisely decided to first blow off dust and other smallish particles of them, while the monitor was still on, with a balloon air blower that I use for case and components
https://photosol.com/products/orbit-hepa-blower/
and at one point I heard small creaking noise from around the buttons. Now I am worried I may have pushed some small particle inside, which caused an electric short. There was no black screen or visual artifacts since, but I am afraid the VRR/GSync and Pulsar capabilities may have been compromised in some manner.
Is anyone knowledgeable about the design of the monitor, to know whether such a thing is possible, or whether the buttons are sufficiently snuggly fitted into the backplate to prevent such thing?
liquidshadowfox
Post by liquidshadowfox » 05 Jun 2026, 09:55
Wouldn't it be possible for them to offer a global flash mode for 240 hz - 360 hz in that 24 - 25" mode and tune it such that the crosstalk is towards the top and bottom of the screen where the black bars is so they don't have to compromise using the rolling scan? Or would the crosstalk still be an issue you guys think?
mawi
Post by mawi » 05 Jun 2026, 14:06
daviddave1 wrote: ↑
04 Jun 2026, 20:06
Tnx so Pulsar only works with custom resolutions on 240hz? I am confused cause msifanboy says he can use cru to make a 360hz custom res with 360 Hz just above this message
Pulsar works with 240 Hz and 360 Hz. Of course its VRR so it works with all kinds of refresh rates inbetween but the global refresh rate must be either 240 Hz or 360 Hz.
I just described "my" method to unlock custom resolutions and super sampling and to get rid of any black screen issues by disabling display tiling. This leads automatically to a maximum refresh rate of 240 Hz as these older cards cannot process a 360 hz signal without tiling the screen.
With custom resolution you can add 300 Hz, which still works with gsync. But not with pulsar. I hope Nvidia will add a 300 Hz pulsar mode. That would be the perfect solution for me as an rtx40 user.
I have not tried any other external tools to add refresh rates or custom resolution to the nvcp. If that works without disabling tiling, that is nice. I doubt it will get rid of the black screens with alt-tabbing in Fullscreen exclusive games.
I have prepared two videos which show this issue with tiling enabled (360 Hz - but this is the same with 240 Hz as well when tiling is enabled) vs. tiling disabled 240 Hz:
1) 360 Hz - Default setting
https://www.youtube.com/watch?v=oHVfp5-c1DQ
2) 240 Hz - Tiling disabled
https://www.youtube.com/watch?v=WVciry_gVNc
If you are into retro gaming and start multiple games throughout an evening, play around with settings etc. and you see these black screens each time. Its frustrating.
Yes, borderless windowed works much better. And it seems with "Control Panel --> Manage 3D Settings --> Power Management Mode, set to Prefer Maximum Performance" 360 Hz is working without ingame black screens.
But for me its not an option. I am running my monitor with tiling disabled since weeks now with 240 Hz. CS2 works like a charm, so do all the other games since fw 1.1.6. If they reduce the 240 Hz latency (which i do not feel at the moment) even more on fw 1.1.7 as stated, then even better.
kyube
Post by kyube » 05 Jun 2026, 14:12
https://www.nvidia.com/en-us/geforce/fo ... changelog/
So only the ACER & ASUS model had the PW slider from launch... :D
I like how there still isn't a mention of 240Hz / 360Hz ULMB2 behavior being "broken" (inferior to their predecessor model)
Can someone write about this on their forums? Though, I assume they've seen my nagging at least once. :)
1.1.7 is seemingly coming out around beginning of July.
MSIfanboy
Post by MSIfanboy » 05 Jun 2026, 16:19
with ulmb2 at 240hz on both pulsar and pg27aqn, the pg27aqn looks sharper, the pulsar has a slight blur, HAZE, LIKE I HAVE MYOPIA and the pulsar doesnt fix it i was thinking maybe screen coating, or that this implementation is worse than pg27aqn
pg27aqn at 1920 pixels/sec looks clearer than asus pulsar at 1440 pixels/s at both 240hz ulmb2
*even on 360hz both ulmb2, pg27aqn looks 33% clearer (as in pixel speed needed to match clarity)
brownvim
Post by brownvim » 05 Jun 2026, 16:35
MSIfanboy wrote: ↑
05 Jun 2026, 16:19
Its probably because its a lower duty cycle, Pulsar and ULMB2 at 240/360hz is 25%. Only the 60hz mode goes lower currently, followed by 120hz in the next firmware update.
I think they mentioned on the Nvidia forum that it introduced crosstalk going lower at the higher refresh rates at the top and bottom of the screen. I'm guessing the pg27aqn is the same?
MSIfanboy
Post by MSIfanboy » 05 Jun 2026, 16:42
so what is going on? they just dont want to make it clearer, they dont want to nerf max brightness? its bizarre
* crosstalk with ulmb2 at top and bottom isnt even that bad, its not like dyac+ which was horrid, i didnt find much of any issue with pg248qp and pg27aqn, just the brightness increase is what i wanted, i thought rolling scan was the solution to the crosstalk mismatch
brownvim
Post by brownvim » 05 Jun 2026, 16:57
Maybe worth requesting it on their forum and tell them about your experience on the other monitors.
I asked for the 120hz mode with the clarity of the 60hz and they are going to implement it.
MSIfanboy
Post by MSIfanboy » 05 Jun 2026, 17:03
brownvim wrote: ↑
05 Jun 2026, 16:57
if the 120hz is something like 60hz 10-30 but brighter, that would be insane
