[Thread Superseded] G-Sync 101 w/Chart (WIP)
Locked
Re: G-Sync 101 w/Chart (WIP)
Post by jorimt » 12 Mar 2017, 22:06
MT_ wrote:So 55fps in game cap with V-sync off is still showing some occasional tears on the bottom of screen and once in a while somewhere in the middle.
Is that a guideline that I should probably even go lower if I want V-sync on with no latency? I feel there are random times where input latency differ still, I guess this happens when the tear would occur in the middle of the screen when Vsync is off.
The in-game cap just fluctuates a lot, especially when assets are being loaded or the engine stalls.
Seems 54~fps is much safer.
To start, as my OP showed, there doesn't appear to be any benefit to G-Sync + v-sync off + fps limit over G-Sync + v-sync on + fps limit, at least if you're looking for a 100% tear-free experience.
With G-Sync + v-sync off, you're going to get tearing, period. That, and you have to lower the fps limiter a considerable amount more, just to have less (bottom) tearing, when compared to G-Sync + v-sync on, which only needs 2-3 frames below the display's refresh rate limit to avoid v-sync-level input latency, and it's tear-free.
As for frametime spikes during asset loads (etc), that's unavoidable with virtually any configuration. I also don't see how a lower fps limit would help in these situations, as the framerate is lowering, not raising during these spikes.
That said, while no syncing method (or lack thereof) is immune to frametime spikes, I assume certain methods allow the framerate/frametime delivery to recover from these instances more quickly.
So yes, it's possible in certain instances, that the frametime compensation G-Sync implements during frametime spikes (to avoid tearing) could cause slower recovery after a frametime spike when compared to G-Sync + v-sync off, or standalone v-sync off.
MT_
Post by MT_ » 13 Mar 2017, 12:26
Yeah, its all getting clear to me now. I saw your older post about your own findings and I pretty much sense the same behavior here.
I have no option but to run Vsync off though, and try to eliminate any possible engine stutter as much as I can.
I really do think that having a 120hz or so monitor would ease much of the pains of G-sync versus 60hz, and I can only hope someday i can replace my godly XB321HK but for now there is little alternative unless I want to lose my 4K and 32" Size :C
LTSC 21H2 Post-install Script
https://github.com/Marctraider/LiveScript-LTSC-21H2
System: MSI Z390 MEG Ace - 2080 Super (300W mod) - 9900K 5GHz Fixed Core (De-lid) - 32GB DDR3-3733-CL18 - Xonar Essence STX II
MaxiJazz
Post by MaxiJazz » 14 Mar 2017, 05:28
Greetings @jorimt!
Recently one guy on Russlan forum (overclockers.ru) foung registry key for disabling "Table fog". He said, that this greatly help with minimize camera input lag in games.
https://forums.overclockers.ru/viewtopi ... agecontent (Use auto google translate)
You need to add DWORD key in HKEY_LOCAL_MACHINE\SOFTWARE\nVidia corporacion\Global\NvTweak
https://forums.overclockers.ru/download ... &mode=view (screen)
Screen with disabled "Table fog" - https://forums.overclockers.ru/download ... &mode=view and https://forums.overclockers.ru/download ... &mode=view
Tried this on my laptop and it likes more sensitive for input (placebo?)
Can you measure it in "numbers" \ does it make sense to G-sync displays? (Don't tried it yet on my desktop with G-sync, only laptop w\o it)
Sorry for my bad English, hope you understand me. :D
P.S. Thx for your testing, it's really helpful.
Post by RealNC » 14 Mar 2017, 09:44
MT_ wrote:I really do think that having a 120hz or so monitor would ease much of the pains of G-sync versus 60hz, and I can only hope someday i can replace my godly XB321HK but for now there is little alternative unless I want to lose my 4K and 32" Size :C
Yes, since you're on 4K, I would not recommend buying a new monitor, since the very near future (couple of months) looks like this:
www. **************** .com/reviews/acer-predator-xb272-hdr-review
Well, if you're willing to pay, that is :-P
Post by Chief Blur Buster » 14 Mar 2017, 11:40
MaxiJazz wrote:Greetings @jorimt!
Thanks for your suggestion! This merits worth investigation.
I've now recently sent jorimt a modified computer mouse (LED attachment) for even more accurate GSYNC testing. He should be posting some really great data in the coming weeks!
MT_
Post by MT_ » 14 Mar 2017, 12:39
I'm willing to pay 1500+ bucks for a 32" version :P
Post by RealNC » 14 Mar 2017, 13:13
MT_ wrote:
RealNC wrote: Yes, since you're on 4K, I would not recommend buying a new monitor, since the very near future (couple of months) looks like this:
I'm in the same boat, but I highly suspect that 1500 bucks will be what they charge for the 27" version...
I guess I'll just have to sell a kidney and a testicle :lol:
akirru
Post by akirru » 15 Mar 2017, 08:26
I would like to start by saying thank-you for all of your hard work jorimt :D
I just had a quick question to ask you. Does it matter at all if you change the pre-rendered frames whilst gsync is activated? I'm quite sensitive to mouse lag. And I usually set it to pre-rendered frame "1" ... I just wanted to find out if its recommended to do this whilst using G-sync.
Thanks
Andrew
Post by RealNC » 15 Mar 2017, 08:51
akirru wrote:I just had a quick question to ask you. Does it matter at all if you change the pre-rendered frames whilst gsync is activated? I'm quite sensitive to mouse lag. And I usually set it to pre-rendered frame "1" ... I just wanted to find out if its recommended to do this whilst using G-sync.
Since he didn't test for that specifically (yet?), you can try and set it to the maximum value possible (in NVidia Inspector; the NVCP setting doesn't go high enough while Inspector goes up to 7 or so) and see whether you get huge mouse lag. If you can't tell a difference between 1 and the max value, then it seems it doesn't matter.
Make sure you test several games though, since not all games are actually affected by that setting in the same way. I know Skyrim is affected by this for sure, so best start with that one.
MT_
Post by MT_ » 16 Mar 2017, 17:57
akirru wrote:I would like to start by saying thank-you for all of your hard work jorimt :D
Thanks
Andrew
As RealNC said, it depends on game. Some games force their own pre-rendered frames setting I believe, albeit rarely.
Personally I've noticed huge lag (but also a tiny bit more stable frametimes) in my game with pre-rendered at 8, so the effect is definately not negated by G-sync.
Locked
