Is it true Ryzen has higher input lag than Intel? Is there conclusive data to prove this?
BTRY B 529th FA BN
Re: Is it true Ryzen has higher input lag than Intel? Is there conclusive data to prove this?
Post by BTRY B 529th FA BN » 11 Aug 2020, 18:11
canx66
Post by canx66 » 11 Aug 2020, 18:16
MaxTendency wrote:
11 Aug 2020, 18:05
canx66 wrote:
11 Aug 2020, 17:33
Thank you for your answer! The fricking 10900k is not available in my country, so I want to buy the 10700k. Whats your opinion about that?
Pretty good processor. KF usually are lower priced and oc better, so check for that one. However in some countries KF maybe more expensive than K , in which case I'd probably go for the cheaper of the 2. Also for 10700k/kf Unify or Aorus Ultra ITX should be fine, you can also go Apex if you really have lots of money to spare.
Thank you! I wanted to buy the ASUS Z490-E Strix, bc ASUS was always good for me. Whats wrong with that? Are the Aorus ones better?
Happyalive
Post by Happyalive » 11 Aug 2020, 18:40
Shorter traces and 2 dimms, compared to normal 4dimm atx motherboard.
johny_ro
Post by johny_ro » 28 Aug 2020, 11:04
MaxTendency wrote:
11 Aug 2020, 16:29
Also if you're going all out on input delay 5700xt might be worth looking into, the general consensus that (non-vega) amd gpus are snappier than nvidia gpus.
Can u pls provide more info on this? H2H results, maybe?
Thnx
RamenRider
Post by RamenRider » 14 Sep 2020, 07:32
This thread is bullshit. 99% of Input Lag comes from Windows Desktop Rendering and DWM.
Post by RealNC » 14 Sep 2020, 10:15
Common sense prevailed in the end.
Caronizeeee
Post by Caronizeeee » 18 Sep 2020, 00:10
People may have already responded in the course of the topic, but I'm from Brazil and I don't understand much English, making it difficult to understand and read message by message, or watch any video.
I have a Ryzen 7 3700x, 2x8gb 3200mhz and RTX 2070. It means that someone with an Intel processor equivalent to my Ryzen and the same setup, has the most responsive game that I have? How much? Is there any way to improve this on Ryzen to look like Intel? I ask this because I like to play competitively and use a 240Hz monitor for example. Thank you
deama
Post by deama » 18 Sep 2020, 05:06
Caronizeeee wrote:
18 Sep 2020, 00:10
It depends on your CPU GHz and memory latencies and clocks, you've given your memory clock, but what's your CPU clock speed and what's the memorie's latency speed?
Caronizeeee
Post by Caronizeeee » 18 Sep 2020, 14:56
deama wrote:
18 Sep 2020, 05:06
Caronizeeee wrote:
18 Sep 2020, 00:10
My CPU is around 4.25ghz on all cores. The memory teams (I did a light OC) are:
tCL: 16
tRCDWR: 18
tRCDRD: 19
tRP: 19
tRAS: 38
