BenQ Zowie XL2546K 240hz TN
Re: BenQ Zowie XL2546K 240hz TN
Does anyone know here or has tested this monitor at lower HZ like 120 or 144? How does it peform latency wise then?
samnotyall wrote: ↑25 Nov 2020, 16:14Would the K version be worth it over the regular XL2546? The regular one is $30 off on Amazon right now, so I'm wondering if the 1/2 ms decrease in response time (because DyAc seems to be pretty much the same) is worth $30.
Totally agree with you axaro1, and @samnotyall, yes, it's very worth it to pay more for the "K" version over the regular XL2546. The "K" model is significantly better, especially in panel performance (motion clarity) over its predecessor, in my opinion. The new Fast Liquid Crystal panel is definitely a significant upgrade.axaro1 wrote: ↑26 Nov 2020, 03:04for $30 you are getting:
- A much faster panel, the old one used on the XL2546 and 2540 has a 4.1ms G2G panel according to RTings, this one is probably at 2ms (or even sub 2ms)
- Refined Dyac
- New OSD
- New stand
- 3x HDMI 2.0 + 1 DP 1.2 compared to 1 HDMI 2.0 + 1 HDMI 1.4 + 1 DP 1.2
I want to add that my XL2546K model doesn't even suffer from the vertical lines issue.
The XL2546 should cost 100$ less than the K model, there is no reason for the two monitors having the same pricing.
I'm currently testing XL2546K and it's easily the best high refresh rate TN monitor I've ever used, and the first one to be free from pronounced pixel inversion artifacts (for example, my XL2546 had terrible pixel inversion artifacts, aka "vertical lines issue"). I am pleasantly surprised with how good this monitor is, saying it as someone who rather prefers IPS panels in general.
I am using xl2546k for a week now. It can be better but i dont think anything can compete with dyac+. Its so good that while i do fast rotation in fast paced combat during rocket jumps. My eyes register the enemy so clearly but my mind cant pinpoint the exact location. Its that good. Im still adjusting to it. But i dont see myself playing on anything less clearer than this. No way jose.
Is this an upgrade to an Omen X 25f? I only play CSGO and I am happy with my Omen... Just wanted to see if this is worth the $$$.speancer wrote: ↑27 Nov 2020, 17:39samnotyall wrote: ↑25 Nov 2020, 16:14Would the K version be worth it over the regular XL2546? The regular one is $30 off on Amazon right now, so I'm wondering if the 1/2 ms decrease in response time (because DyAc seems to be pretty much the same) is worth $30.Totally agree with you axaro1, and @samnotyall, yes, it's very worth it to pay more for the "K" version over the regular XL2546. The "K" model is significantly better, especially in panel performance (motion clarity) over its predecessor, in my opinion. The new Fast Liquid Crystal panel is definitely a significant upgrade.axaro1 wrote: ↑26 Nov 2020, 03:04for $30 you are getting:
- Refined Dyac
- New OSD
- New stand
Oh, yes, in my opinion Zowie XL2546K is far superior over Omen X 25f, in all motion handling, ergonomics, strobing (which the Omen does not have at all), features (like Black eQualizer) and build quality. My unit of X 25f also suffered from significant pixel inversion artifacts. X 25f's motion clarity in-game looked actually worse to me than on ASUS VG259QM (280 Hz IPS).
I deeply appreciate your input @speancer! I had been stuck between Zowie vs Asus (280hz) vs Msi, and your comment settled it for me. Considering my main game is CS:GO, and that I have other displays to do audiovisual work with, I believe that the Zowie is the best gaming monitor (particularly shooters) one can go with right now.speancer wrote: ↑27 Nov 2020, 17:39samnotyall wrote: ↑25 Nov 2020, 16:14Would the K version be worth it over the regular XL2546? The regular one is $30 off on Amazon right now, so I'm wondering if the 1/2 ms decrease in response time (because DyAc seems to be pretty much the same) is worth $30.Totally agree with you axaro1, and @samnotyall, yes, it's very worth it to pay more for the "K" version over the regular XL2546. The "K" model is significantly better, especially in panel performance (motion clarity) over its predecessor, in my opinion. The new Fast Liquid Crystal panel is definitely a significant upgrade.axaro1 wrote: ↑26 Nov 2020, 03:04for $30 you are getting:
- Refined Dyac
- New OSD
- New stand
-----HOW TO ENTER THE FACTORY MENU-----
1) Switch OFF the monitor
2) Press the 5 way wheel on the back of the monitor and keep it pressed
3) Switch ON the monitor by pressing the right side button on the back of the monitor.
I'll try to find how to get inside the service menu aswell
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
*= currently owned
Does anybody know the release date of XL2746K? is it coming soon? XL2746S and XL2746K has the same panel as 2546S and K series?
I don't think that the XL2746S is out of production like the XL2546S and there are no rumors about Zowie working on the XL2746K.
*= currently owned
*= currently owned
Btw if you own the XL2546K and you see no difference between OD High and OD Premium try running an ufotest at 2400 pixels per second, you'll see that the amount of overshoot behind the ufo is slightly reduced with High* (this is impossible to see at the standard 960pps ufotest).
*If you are not using Dyac
*= currently owned
*= currently owned
