Page 12 of 127
Posted: 29 Jun 2021, 09:30
by BTRY B 529th FA BN
Posted: 29 Jun 2021, 10:03
by Pazos
Discorz wrote: ↑
29 Jun 2021, 09:15
Pazos wrote: ↑
29 Jun 2021, 08:07
i uploaded my original video not as nice aligned what do you think of it?
Still the same.
Try with theese basic instructions.
BTRY B 529th FA BN wrote: ↑
29 Jun 2021, 08:32
That image of the PG259QN does not reflect what I see with mine at 360Hz. I've been trying to do a video with my iPhone 7 HD 60fps and I can't record a video that reflects what my eyes see. I think I'm not holding the phone steady and it's trying to focus.
EDIT: my eyes are seeing more like what the VG279QM @ ELMB 280Hz and MAG251RX AMB 240Hz shows.
Backlight strobing enabled?
Usually parts around alien eyes, white windows/lights and black lines in between is hard to perfectly capture, everything else can be very close.
i did it now with manual settings is it fine or do i have to get closer and only follow one ufo?
https://youtu.be/4YJbO-XjR28
Posted: 29 Jun 2021, 10:17
by Discorz
Pazos wrote: ↑
29 Jun 2021, 10:03
This is much better.
But image detail i burnt out lost due to high ISO setting. Try lower or reduce monitor brightness until you get the closest result your eyes see.
Posted: 29 Jun 2021, 10:34
by Discorz
29 Jun 2021, 09:30
240pps speed is way too slow to test motion performance. Thats why it looks so clear. 960 is default and stick to that one and use ghosting test instead of "stars" background. Even tho 1920+pps would be a better speed to match fast gaming motion.
Try different camera settings
There are already a bunch of pursuit shot of PG259QN /R. Check em in this collection.
Posted: 29 Jun 2021, 10:37
Posted: 29 Jun 2021, 10:39
by Pazos
Discorz wrote: ↑
29 Jun 2021, 10:17
Pazos wrote: ↑
29 Jun 2021, 10:03
another try :-) its not that easy https://youtu.be/xKW3tKpvDLU
Posted: 29 Jun 2021, 10:47
by Discorz
Pazos wrote: ↑
29 Jun 2021, 10:39
Getting there, more details, pronounced steering wheel... Looks better. :)
Ghosting trail seems to be missing because its too dark. Use higher recording resolution if u have.
Posted: 29 Jun 2021, 10:48
by kyube
Could ya'll vote for this monitor to be reviewed by RTings? Think they'll do a good job at telling us if it's good.
www-rtings-com/monitor/suggestions (cant link it for some reason lol...)
Posted: 29 Jun 2021, 11:00
Posted: 29 Jun 2021, 11:21
by Discorz
29 Jun 2021, 11:00
There you go. Good :D . PG259QN @360Hz OD Normal
It appears cleaner in reality because the focus is a bit off and ISO is on a high side + 4k30 will do better.
